If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
NOTE(((excessive calcium build up inside the
dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called
Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
