Question about HP Compaq Business Notebook NX9010
Remove floppy drive compaq nx9010
How do I access the floppy drive to replace
    Genius:
  • 2,028 Answers
You can try the link below. It should have a breakdown diagram. If I may ask why, I'm a computer tech, and I've only used my floppy drive two times in the last three year, and that was to make a bios flah for a couple of ancient machines. Your laptop is relatively new.
Posted on Jun 24, 2008
How to boot hp nx9010 from usb to install windows xp because it's cd drive is not working
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions, perhaps some are covered here.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
Nov 17, 2010 | HP Compaq nx9010
Can't access CD
If you mean the drive won't open then
Turn off computer
Locate a small hole in DVD drive lid.
Carefully insert a straightened paper clip.
Gently push & the lid should pop out.
Then you can open the drive & remove the CD
Restart the computer and see if it opens normally and reads dvd's now.
If you mean Windows won't read it then the drivers may need re-installing. Check in hardware manager to see if Windows recognizes it or shows an error for it.
May 17, 2010 | HP Compaq nx9010
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
Loose USB connection in laptop
You can't do that repair unless you are a experienced circuit tech.
May 23, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
How do I remove the hdd from compaq nx9010?
Hi - follow these steps and picture:
. Remove the hard drive by following these steps:
a. Remove the two rubber screw covers 1 that conceal the
hard drive retention screws.
✎Spare part number 371808-001 should be used to replace
the hard drive rubber screw covers.
b. Remove the two PM2.0×6.0 screws 2 that secure the
hard drive to the notebook.
c. Use the notch in the hard drive bezel to slide the hard
drive forward 3.
d. Remove the hard drive.
864136d.gif If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 21, 2008 | HP Compaq Business Notebook NX9010
USB external floppy drive
In windows XP and later the USB mass communication driver are in built, so you can use these devices like USB Floppy drive, USB HDD, Memory card, flash memory etc...
But before windows XP Microsoft did not supply the driver for USB mass storage devices. So, in your case you have to install the Driver for your USB Floppy drive, then you can use this drive as Floppy drive but after complete boot of your Windows 95.
If any problem or more question Just Ask me
Thanks
Iqbal
Apr 07, 2008 | HP Compaq Business Notebook NX9010
Nx9010 power on problem
choose load default settings then save and exit.
then we;ll go from there.
keep me informed
Mar 08, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Compaq NX9010
Yes the problem is solved. I unplugged the computer and removed the battery for a couple minutes. Then replugged in everything and it is working fine. Go figure.
Feb 20, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Presario 2500 hp
just google Compaq Presario NX9010 replacement DC Jack
Jan 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Hp compaq nx9010 notebook pc
lol ;) Much harder than with a pc.
But you need to remove the battery for it. I am afraid it would require taking the keyboard out.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00246219/c00246219.pdf
here is the manual to help with the process.
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Compaq Business Notebook NX9010 Logo
256 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
