Question about IBM ThinkPad R50e Notebook
Thinkpad R50 Reboot problem
Have a Thinkpad R50. Running on battery, it boots up to desktop.. then reboots. This happens time after time. If I plug it in and use the AC adapter, it boots up and runs fine for hours on end. But I don't want to have to be tethered to a plugged in laptop. Help?
  • 3 more comments
  • dandylawn Jun 24, 2008
    I checked the configurations. I set them all to NEVER hiberate or shut off. saved the configs. Then, I unplugged the power supply. The battery charge indicated it was at 100%. I started playing a solitaire game and in less than 30 seconds, the machine rebooted. Plugged the ac adapter back in.. and it's still up and running 1.5 hours later.
  • friend_1778 Jan 05, 2009
    Did changing the battery helped?
  • Anonymous Jan 21, 2009
    reboots on battery
  • Anonymous Feb 01, 2009
    hi i have the exact same issue with r50e anf 2 diffrent batteries.
    any progress?
  • Neal Brown May 11, 2010
    Have you checked your 'power configuration' when on battery? You should be able to access all of the different configurations while on A/C power so you're not fighting the rebooting mess.
    It could be that the system is set to hibernate or whatever after SX number of minutes of inactivity, and it is making it look like a full reboot.
  • 2,028 Answers
Try a different battery. Then come back.
Posted on Jun 24, 2008
Screen goes black
your display is conflicting with another driver. best booting into safe mode, disable all drivers except display and reboot, once display is configured u can enable each driver individually and reboot each time!!
Sep 04, 2013 | Lenovo ThinkPad T61 Notebook
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
So what happens when you press the power button to turn the computer on? Your statement doesn't tell us very much. When you say it won't let you read anything sounds like something is display on the screen but you can't read it. Is that true? And you said reboot either? You can always cut the computer off and press the power button to try and reboot it, even thought it might not be successful. Explain what is happening more clearly.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | E-Machines eMachines Desktop PC
I have IBM r50 that won't boot.
i think i have the same problem , i also have an ibm r50e and one day when i tried to turn it on it did the same thing . all the lights turn on and the only the battery and the left side light with akind of ray inside a circle stand on , it started on after a severl intents but im worried about the situation , i been looking on the web for the solution and your comment is the only thing i have found about the problem i will continue looking for the solution or cause . GOOD LUCK
Apr 14, 2010 | IBM ThinkPad R50e Notebook
Had plug and play config f1 f2 error message problem. replaced battery message went away but can not boot up
boot to BIOS Press ALT+E (1 Beep) Press ALT+F (1 Beep) Press ALT+B (Reboot)
see what happens
Dec 14, 2009 | Dell Dimension 8200 PC Desktop
Restore default settings for ibm thinkpad r50
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. thanks and have a nice day J-
Nov 26, 2009 | IBM ThinkPad R50e Notebook
Lenova IBM Thinkpad notebook boots and comes upto desktop screen, but beyond that it hangs, does not take mouse clicks, unable to navigate the desktop
you may have a virus. try this go to control panel add/ remove reboot go to on the right side look for support click . the name bran does not matter, drop own list , look for the fit, that best fit the type you have and download driver. reboot computer with mouse plug in, an it should wo.rk
Jun 03, 2009 | IBM ThinkPad R50e Notebook
When stat thinkpad R50 beeps 2x and nothing
Two short beeps and no further activity mean you could have a motherboard problem or a memory (RAM) problem.
Reseat the RAM modules and reboot the laptop, if the laptop still doesn't work, remove the RAM module/s and insert them into a working laptop to test them, or take them to you friendly computer shop to have them tested.
If the RAM is OK then the fault is the motherboard. Replacing the motherboard may not be a cost effective solution.
May 14, 2009 | IBM ThinkPad T40 2373 Notebook
T23 Thinkpad turns off during boot after restart
My guess would be ;-
A power supply problem with the battery and/or power adapter
The most likely one.
The CPU is overheating and shutting down and if you wait a while and it will power it up again, it will then run for a while and shut down again.
This can be caused by a faulty fan (its not spinning and needs to be replaced) or the vents are clogged with dust (needs to be cleaned and you may need to remove the fan assembly to do this).
Jan 27, 2009 | IBM ThinkPad T23 2647 Notebook
This slim CD Rom is compatible with the Cubid and Travla mini ITX cases.
This is also compatible with:
Portege 3440CT, Portege 3480CT, Portege 3490CT, Portege 4000, Portege 4000CT, Portege 4005, Portege 4010, Portege M100, Portege M200, Portege M205, Portege M205-S809, Portege M205-S810, ProLiant Content Delivery , ProLiant DL140, ProLiant DL320, ProLiant DL360, ProLiant DL380 G2, ProLiant DL380 G3, ProLiant DL560, ProLiant DL560 R01, ProLiant DL580, ProLiant DL585, ProLiant DL590, ProLiant DL590 R01, SAN Management, Satellite 1550CDS, Satellite 1555CDS, Satellite 1715XCDS, Satellite 1730-S101, Satellite 1730CDT, Satellite 1735-S101, Satellite 1800, Satellite 1800-S203, Satellite 1805, Satellite 1805-S203, Satellite 2060CDS, Satellite 2065CDS, Satellite 2100CDS, Satellite 2100CDT, Satellite 2105CDS, Satellite 2140CDS, Satellite 2140XCDS, Satellite 2180CDT, Satellite 2210CDT, Satellite 2210XCDS, Satellite 2215XCDS, Satellite 2230CDS, Satellite 2250CDT, Satellite 2250XCDS, Satellite 2255XCDS, Satellite 2510CDS, Satellite 2515CDS, Satellite 2520CDS, Satellite 2530CDS, Satellite 2535CDS, Satellite 2540CDS, Satellite 2540CDT, Satellite 2540XCDT, Satellite 2545CDS, Satellite 2545CDT, Satellite 2545XCDT, Satellite 2590CDS, Satellite 2590CDT, Satellite 2595CDS, Satellite 2595CDT, Satellite 4000CDS, Satellite 4000CDT, Satellite 4005CDS, Satellite 4005CDT, Satellite 4010CDS, Satellite 4010CDT, Satellite 4015CDS, Satellite 4015CDT, Satellite 4020CDT, Satellite 4025CDT, Satellite 4030CDS, Satellite 4030CDT, Satellite 4060CDT, Satellite 4060XCDT, Satellite 4070CDS, Satellite 4080XCDT, Satellite 4085XCDT, Satellite Pro 4600 (14.1), Satellite Pro 4600 (15), Satellite Pro 6000 (14.1), Satellite Pro 6000 (15), Satellite Pro 6100 (14.1), Satellite Pro 6100 (15) , Satellite Pro 6100 (15 SXGA), Satellite Pro 6100 (15 UXGA), Satellite Pro M10, Satellite Pro M10-S405, Satellite Pro M10-S406, Satellite Pro M10-S407, Satellite Pro M10-SP405 (14.1), Satellite Pro M10-SP405 (15), Satellite Pro M15-S405, Satellite Pro M15-S406, SUN FIRE V100, SUN FIRE V120, Tecra (14.1) , Tecra (14.1 SXGA) , Tecra 8000, Tecra 8000 (12.1), Tecra 8000 (12.1 STN), Tecra 8000 (13.3), Tecra 8000 (14.1), Tecra 8000 (14.1 PIII) , Tecra 8000STN, Tecra 8100, Tecra 8100 (13.3), Tecra 8100 (14.1), Tecra 8200, Tecra 9000, Tecra 9100, Tecra PE2100, Tecra S1 (14.1), Tecra S1 (15) , Tecra S1 (15 UXGA), Tecra TE2000, Tecra TE2100, ThinkPad 1300 1171 (12.1) , ThinkPad R50 1829 (14.1) , ThinkPad R50 1829 (15.0) , ThinkPad R50 1830 (14.1) , ThinkPad R50 1830 (15.0) , ThinkPad R50 1831 (14.1) , ThinkPad R50 1831 (15.0) , ThinkPad R50 1836 (14.1) , ThinkPad R50 1836 (15.0) , ThinkPad R50 1840 (14.1) , ThinkPad R50 1840 (15.0) , ThinkPad R50 1841 (14.1) , ThinkPad R50 1841 (15.0) , ThinkPad R50e 1834 (14.1) , ThinkPad R50e 1834 (15.0) , ThinkPad R50e 1842 (14.1) , ThinkPad R50e 1842 (15.0) , ThinkPad R50p 1832, ThinkPad R50p 1833, ThinkPad R51 1829 (14.1) , ThinkPad R51 1829 (15.0) , ThinkPad R51 1830 (14.1) , ThinkPad R51 1830 (15.0) , ThinkPad R51 1831 (14.1) , ThinkPad R51 1831 (15.0) , ThinkPad R51 1836 (14.1) , ThinkPad R51 1836 (15.0) , ThinkPad R51 1841 (14.1) , ThinkPad R51 1841 (15.0) , ThinkPad R51 2883 (14.1) , ThinkPad R51 2883 (15.0) , ThinkPad R51 2887 (14.1) , ThinkPad R51 2887 (15.0) , ThinkPad R51 2888 (14.1) , ThinkPad R51 2888 (15.0) , ThinkPad R51 2889 (14.1) , ThinkPad R51 2889 (15.0) , ThinkPad R51 2894 (14.1) , ThinkPad R51 2894 (15.0) , ThinkPad R51 2895 (14.1) , ThinkPad R51 2895 (15.0) , TRANSPORT NX
Mar 05, 2008 | Computers & Internet
IBM ThinkPad R50e Notebook Logo
235 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
