Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Can't connect to internet
I can't connect to the internet even though the card and router appear to be talking to each other. When you view the properties via the network connections tab it says "aquiring network address". I then put the ip addresses in manually and it shows as connected but when I launch explorer it says there is no connection. The connection is fine with the same explorer settings via the ethernet card/cable.?? intermittant connection to the internet...continually "aquiring network address"
    Novelist:
  • 105 Answers
It sounds like the driver for the USB network device is not loaded correctly. So, you'll need to reinstall it from scratch. Unplug everything, install the software, then reattach the usb cable to the PC.
The other thing is, did you DISABLE the network adapter that was already in your PC when you added the USB network adapter? If not, you need to do that. If they are both active but only one is connected, the system could still be trying to use the other network adapter and tying up the resources in the process.
Posted on Jun 24, 2008
Can connect to router but not internet
Ok so the router will broadcast even without an IP from the modem. Without the IP even though your pc is talking to the router you will have no internet. The IP is assigned to the modem from your ISP "internet service provider" The router has to assume the IP then assign a mac address to the pc using the internet. A residential modem meaning your not a business is given a dynamic IP which can change at anytime the blade server wants it to. A business gets a static ip which never changes. There lies your issue. Whats happened is your modem has been assigned a new IP and the router is still trying use the old IP. So unplug your modem and router. Plug the modem back in and let it sync up. Once all the lights are back on "with exception for the "link" light plug the router back in give it a cpl minutes your internet will work again.
Apr 03, 2014 | Acer Computers & Internet
I have a PC running windows 7 connected to the internet via Verizon dhl but whenever I try to connect a wrt54g router I lose the internet connection even though the modem appears to be working with all...
I had the same Linksys router, and the same issue as well. I continually reset it. Resetting the router would provide better connectivity to my laptop, but it would fail all to soon. I wound up switching routers, and the issue was resolved. I would recommend that you rest the router and see if that helps. If not, then I would recommend a new router.
Mar 12, 2011 | Linksys Wireless-G WRT54G Router
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Belkin wireless g plus mimo router
YOu may have configured static ip address in your desktop computer...
CHange IP setings to obtain Ip address automaticaly.....
or follow
  1. Open Windows Start menu.
  2. Open Control Panel.
  3. Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and then Network Connections.
  4. Double-click on your active LAN or Internet connection.
  5. Click Properties.
This opens the Local Area Connections Properties window.
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and click Properties.
  • In the General tab, click
    Obtain IP address automatically....
    and click ok...
    and try to conect it now...
    Let me know it this helps.... GOod luck...
    rate me..
    Regards,
    Dec 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Internet problem
    If you are talking about a wireless router, try changing the channel that the wireless router is using. Many times there is interference from yours or a neighbors portable phone.
    Aug 26, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
    Belkin mimo network card
    So are you saying that it's not showing any network on the view available network screen? What is the message on the screen?
    What is the model and brand of your wireless router from talk talk?
    Its possible that we may need to check the wireless settings inside the wireless router. Provide me with it's model no. and I will look for a solution for you.
    May 20, 2008 | Belkin High-Speed Mode Wireless G Notebook...
    2 wire 1800 router on talk talk
    hello!
    -- who is your internet service provider
    -- what is the operating system of your computer?
    -- is this working fine before or is this a brand new router
    you may try this and see if this help solve your problem
    Step 1: Shutdown the computer.
    Step 2: Unplug the router’s power cable.
    Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
    Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
    Step 5: Plug in the router's power cable once the modem’s lights appear stable.
    Step 6: Power on the computer on and test the Internet connection.
    if this still didnot work, maybe you need to upgrade the firmware of your router
    Apr 27, 2008 | 2wire 1800HG Router (RG1800HG00)
    Hooking linksys to gigafast
    There are some question's that should probably be asked before we begin. Generally a wireless adapter or network card is present in a computer to allow it to access a wireless router which is connected to an internet service provider (generally a dsl connection through a phone line or a cable modem from your cable provider. Your request seems to be to get a computer to talk to a wireless router to talk to a wireless router to talk to your internet service provider (dsl or cable). I will assume after reading this that you probably have or will get a wireless adapter for the computer to talk to one or both of the wireless routers you appear to have. Wiring two wireless routers in the same house may be useful if the home is large or the wireless routers operate on different bands (a, b, g or frequencies) and you have different computers that require the different bands. however both wireless routers are in my experience connected to each other using a wire. Once we clarify the above we can probably address the connectivity issues for the devices you require.
    Dec 02, 2007 | Linksys Wireless-G Broadband Router
    The issue could be with the wifi connection that your wifi adapter is connected to. If your running a windows based system, go to the system tray and right click on your wifi connection symbol (SSID) and see which network your connected to. Every LAN has its own unique name of their Local area network (LAN), if its not displaying your LAN SSID name but a different SSID name then thats the problem. If thats the case, then once again right click on the wifi connection symbol in the system tray and change the wifi connection to your SSID for "view available connection". Your wifi adapter could be picking up a wifi connection in your area and you do not have access to their LAN.
    Sep 05, 2007 | Edimax (ew-7128g) 802.11g/b Wireless...
    NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
    133 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
