Question about Roper RAS6233KQ Top Load Washer
Necklace wrapped around bottom of agitator
How can i get the agitator off to get to the bottom?
So I have a GE Washing Machine Model Type: GHWP1000MOWW
and my washer ate my necklace and is underneath the agitator. I tried doing that ^ but there's this plastic cover underneath the protective cap! What do i do?
Posted on Aug 31, 2012
  • 413 Answers
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Posted on Jun 24, 2008
  • angelface_85
    angelface_85 Aug 31, 2012
    So I have a GE Washing Machine Model Type: GHWP1000MOWW and my washer ate my necklace and is underneath the agitator. I tried doing that ^ but there's this plastic cover underneath the protective cap! What do i do?
  • Richard
    Richard Sep 01, 2012
    GE agitators are pressed on. To remove, firmly grasp the bottom of the agitator with both hands, one on each side. Pull hard and abruptly, straight up being careful not to hit your face or chin with the top of the agitator.
    Regards;
    reg501
Need to replace the agitator dogs and can't remove the mover from the bottom section
Direct drive Whirlpool washing machines use a two piece agitator. In-between the two pieces there are cogs, sometimes referred to as "dogs," which will wear out. When the dogs start to wear, you will notice a clicking sound and the top agitator will not move as it should. When you learn how to replace the agitator dogs on a Whirlpool washing machine, you can have your Whirlpool working correctly again. Agitator dogs are available at appliance repair facilities.
* 1
Disconnect the Whirlpool washer from the wall outlet. Open the washer lid to access the agitator.
* 2
Insert a flathead screwdriver in the notch in the agitator cap. Twist the screwdriver to pop the agitator cap off of the agitator. If your model has an inner cap, remove the inner cap by pulling up on the handle and removing it from the agitator.
* 3
Use a socket wrench to remove the bolt in the center of the agitator. Most Whirlpool washers use a 7/16-inch bolt to secure the agitator.
* 4
Grab the bottom of the agitator with both hands and pull it straight up out of the wash tub. Do not have your face directly over the agitator. If it is stuck or pops up too quickly you could injure yourself.
* 5
Set the agitator on the floor and carefully place your feet on each side of the agitator. Grasp the top of the agitator and pull the top half of the agitator off of the bottom half. Turn the top half over to access the dogs.
* 6
Use needle nose pliers to pull the dogs out of the agitator. Install the replacement dogs into the agitator according to the specifications given the manufacturer.
* 7
Set the top half of the agitator back on to the bottom half. Make sure to align the two tabs together between the halves so that they will friction fit. Grab the bottom of the agitator and apply a thin coat of dishwashing detergent on the rubber gasket on the bottom using your finger.
* 8
Set the agitator back into the wash tub and secure it using the retaining bolt. If your model had an inner cap, set the inner cap back into the agitator until it snaps into place.
* 9
Place the top of the agitator into place and press down until it locks into place.
Mar 21, 2011 | Whirlpool Washing Machines
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
I can't get top part off the agitator
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you have a 2 part agitator assembly (Fabric softener dispenser, top agitator and main agitator)
First, push down on the ring around the bottom of the fabric softener dispenser and lift it off the agitator.
Pry the top cap (a short screwdriver into the slots in the cap works) of the top agitator.
Looking into the center of the top agitator, you'll see a plastic piece with a 1/2" square hole. Using a 1/2" socket set extension, unscrew the piece carefully. You might have to hold the bottom agitator in place while you do this.
The top agitator pulls up.
You'll see a bolt and screw holding the bottom agitator on. Carefully unbolt this one and the entire bottom agitator will pull up.
Sep 27, 2009 | Washing Machines
Top part of agitator does not move with bottom of agitaor
Hi, Remove the cap on the agitator and locate the 7/16" bolt. Remove the bolt and the agitator will lift out. Seperate the agitator and replace the dog kit inside the upper half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Top of agitator not conncted to bottom
not quite sure as to how your agitator is nol onger connected??? but i looked up by model number and you can order and replace the complete agitator for about $50... ifhte agitator no longer "agitated" and was reemoved to replace teh agitator dogs (which is the most common issue) the the 2 halves of the agitaotr click back together by lining up slots betweeen the two halves.hoping this was a little helpful
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kleenmaid washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid (KAW693W) top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Apr 06, 2008 | Washing Machines
Agitator won't agitate
Replace what is called the dogs in the agitator (part number 80040? i think)
Oct 29, 2007 | Roper RAS8244KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
406 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
