Question about Compaq Computers & Internet
Not accepting command to print. The printer is OK.
    Sergeant:
  • 329 Answers
Go to control panel, printers, find the printer you have, right click, see properties, bottom of page print test, see what happens. Did it ever print. Deleate printer, turn computer off turn on XP or Vista should find printer and install. Then test again as above.
Posted on Jun 24, 2008
Canon mx922 not printing word document from PC. Puts it into queue
How To Fix It - The fix is simple. You need to clear the print queue manually so that all the print jobs currently in the queue are deleted properly - once the queue is empty you should then be able to print new documents without problems. We will show you how below, depending on whether you use XP or Vista/7:
1. XP - click 'Start' then click 'Run' and in the Run window type CMD then press 'OK' - this opens a Command Prompt window. Now skip to Step 3.
2. Vista/7 - click 'Start' and type Command in the search box. Right click on the 'Command Prompt' result in the search results above it and select 'Run As Administrator' - this opens a Command Prompt window.
3. All version of Windows - in the Command Prompt window (these commands are also shown in the picture below):
4. Type net stop spooler then press the Enter key.
5. Type del %windir%\system32\spool\printers\*.* /q then press the Enter key (Note: the only spaces in this command are a single space between del and %, and a single space between * and /q)
6. Type net start spooler then press the Enter key.
7. Type exit then press the Enter key to exit the Command Prompt window.
Fixing the print queue
This should have cleared the print queue (i.e. all print jobs have been deleted) and you can now submit new jobs for printing
What Do These Commands Do?
The Command Prompt is a throwback to the pre-Windows days of Microsoft DOS but is still a useful way to type and enter system commands. The print Spooler is basically the print 'queue' - we need to Stop it running before we can Delete documents stuck in it.
The Del command deletes everything currently held in the print queue, including the 'stuck' document(s). We then have to Start the Spooler (print queue) up again so that it can accept new print job requests in future.
What If It Keeps Happening?
If the problem only occurs occasionally it is likely just due to an incompatibility with the actual data being printed ( a webpage that has unusual fonts or some other format that the printer is unable to convert into printed output - run the above fix to resolve it.)
However, if you find that almost all documents keep getting stuck in the print queue then Microsoft's answer is that it is an issue with your printer drivers (software) - one solution may be to download and update new printer drivers from the manufacturer. You could also try the Microsoft automatic Fix It for printers . This will repeat our fix above but may also flag up/fix any different Windows errors that stop printing.
Other causes may include a misconfigured printer e.g. network printing to an IP address that doesn't exist uninstalling and reinstalling the printer software from scratch should fix this.
Aug 19, 2017 | Canon Office Equipment & Supplies
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
How to send printer commands to TEC SX5 printer
A lot of printers you can put special commands in a text file and just send it as a print job. You will want to consult toshiba for commands. Also lots of printers accept commands via telnet. You can use putty to telnet to the printer. Also many printers have web interfaces to configure them.
Dec 18, 2012 | Toshiba B-SX5T Printer
I have an Epson CX9400Fax all in one printer, fax, scanner. Yesterday it quit accepting print commands from the computer. It still copies, scans and saves scan files from the unit to the computer so I am...
Reinstalling the software is great, but did you first remove your printer usb cable, uninstall the printer and then re-install your software?
If not, do those 3 steps in that order and try printing again.
Best wishes,
Graemevm
Dec 17, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I9900 printer has error 5B00 & won't print
You may need to change the ink absorbers. But try resetting the printer:
Canon I series service mode
1. Start with printer OFF
2. Hold down RESUME and then press and hold down POWER Button.
3. Release the RESUME but continue to hold down the power button
4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print
B. Press the Resume button twice = Print EEprom data sheet
C. Press the Resume button Three = Initialize the EEprom
D. Press the Resume button Four = Clear Waste INk Counter
E. Press the Resume button Five = Change Destination settings
F. Press the Resume button Six = Head Refreshing (Cleaning)
G. Press the Resume buttom Seven, Eight, Nine, = Not used
H. Press the Resume button Ten = Return to selection Menu
To EXECUTE anyone of the above commands you "MUST Press the Power button one time. Then the function will be executed. After that function has been executed the printer will REMAIN in Service Mode,.. waiting for another command. You can only execute one command at a time. If you are through with all the commands you want to do, just press the power buttom one more time and it will turn the printer off and you will be out of Service Mode. One more note. When you get the printer into Service MOde and it is ready to accept a command, the green light will be on and steady. As you issue a command by pressing the resume button, it will alternate the color from green to orange with each press of the resume button. Remember, if you issue either one of the commands to force a print make sure you have paper installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp Photosmart 3310
wow..try a test page to see if the printer is happy on it's own.
Aug 19, 2008 | HP Photosmart 3310 Printer
Change Region On Printer
You will need to contact HP at the support number they provided, tell them that you have a US region printer and need it reset to the UK. The cartridge numbers are different and a US region printer will not accept UK cartridges.
They can do the reset over the phone and there should not be any charge for this. You will need to be at your computer as they will need to have you send some commands to the printer. The reset procedure is not available through the online chat.
This will only need to be done once, after the reset procedure the printer will properly accept the UK cartridges (but no longer accept US cartridges....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 10, 2008 | HP Photosmart 2610 All-In-One InkJet...
LQ 680 dot matrix printer
Try replacing the LPT cable, it's probably messing up the commands sent from the computer and thus, locking the printer.
Feb 07, 2008 | Office Equipment & Supplies
Hp photosmart C3150
Hi it is the issue with the Print spooler
please refresh it :-
  1. Click Start, click Run, type command, and then click OK to display the command.com window.
  2. Type net stop spooler, then press <Enter>.
  3. Type sc config spooler depend= RPCSS start= Auto, then press <Enter>. The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
  4. Type net start spooler,then press <Enter>.
Nov 17, 2007 | HP Photosmart C3150 Printer
Computers & Internet Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
