Question about GPS
Update for the Nextar 14-BC GPS
I was confused by the directions for unzipping files for the update. The instructions specify unzipping only the files to the SD card, not the folder. However, when I extracted the folder, a cab folder was extracted to the SD card. The first time that I turned the GPS on again so that the files could be transferrred from the SD card to the device, all I got was a picture of Mt. Fuji with some Japanese writing and some version of Malata on the screen. I managed to get the GPS to function again-- somehow-- but I don't know if it was updated. What is the latest version? What files should appear on the SD card when the folder has been extracted? Should the cab folder be present? Do I need to do anything to extract the files in that folder?
I hope I was able to explain that without being too confusing. Thanks.
  • Anonymous Jul 24, 2008
    Just as described in the previous post. Sent email to their Tech Support and awaiting their reply.
  • bartandcathy Aug 30, 2008
    same as every one else, waiting for a response from tech support.
    anyone know what the chinese figures mean?
    Bart
I had the same problem. After I removed the SD card and turned off and on the power switch on the back of the unit, the system software was upgraded from 1.1.8 to 1.1.9.x.
You can check by going into the navigation module and then clicking system information.
Posted on Sep 14, 2008
My nextar 14-bct was not on for a long time then I charged battery a short time then when I was playing with it in house it went blank and now will not turn on
I have a nextar 14-bc and I was having similar problem and I found that the power in jack had a broken solder joint and when I thought it was charging it was not. I would not turn on until I discovered the broken solder joint inside on the power jack. I resoldered it and after it charged up it was up and working again. You might check on that.
Aug 19, 2011 | Nextar I4-BC GPS Receiver
I need to update my nextar X3-11 gps and dont know how????
Unfortunately Nextar does not offer an update for your unit. See units with available updates below.
Map Upgrades for GPS:
The below units are upgradable with the Navi Extra maps.
  • Q4: From Serial #ML0909020001 onwards. From Serial #YF0909123953 onwards
  • Q4-06: From Serial # ML0909000001 onwards
  • ME: All serial numbers
  • 43LT: All serial numbers
  • V4: All serial numbers
  • V5: All serial numbers
  • I4-BC: From Serial# ML1004000001-ML1004000504 and ML1005001701-ML1005002700
Important Map Upgrade Information:
Please note that refurbished units that have serial numbers starting with MLR or ML999 are not compatible with map upgrades.
Navi Extra Mapping
Please note that Nextar is unable to answer map support questions once the Navi Extra mapping has been purchased. For any map related questions and/or refunds, please feel free to contact Navi Extra at:https://nextar.naviextras.com/shop/portal/support?selectedTab=contactus.
May 02, 2011 | Nextar X3 GPS Receiver
Nnot find map data files fo x8 nextar
update available here:
http://www.nextar.com/frontend/proddetail.asp?pn=PART-GPS-MAP09SDC2
Nov 09, 2009 | Nextar X3B GPS Navigation System
How do I update my Nextar X3i GPS device?
Go to the manufacturer?s website and it will tell you eveything you need to do either it is you need to download file directly to your GPS device or you might be able to download a the files to your computer and upload them through your USB post
Oct 21, 2009 | Nextar X3I GPS with MP3 Player
Finding the reset hole on the nextar I4-Bc
PDF] I4-BC Hardware Manual.pdf 2345k - Adobe PDF - View as html Global Positioning System ("GPS") hardware, operating software or other aspects of this ... outlet again to reset the player. If the problems still exist, ...www.nextar.com/images/Product/I4-BC Hardware Manual.pdf
Aug 15, 2009 | Nextar I4-BC GPS Receiver
Upates for nextar x4-t are there any?
Require updates for Nextar 14-BCT GPS
Mar 17, 2009 | Nextar X4-T Car GPS Receiver
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
Dont understand my gps
There are updates for a 14-BC is hat what you are looking for? If so follow the link. Hope this works!!!
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=I4-BC&subpr=&categ=
Jan 25, 2009 | Nextar I4-BC GPS Receiver
My nextar x3-08 wont read the sd card
I called Nextar and you have to let its battery drain completely and then plug it in to charge for 5 hours. I guess it a glitch in the system :(
Jan 05, 2009 | Nextar I4-BC GPS Receiver
Are there any POI updates available?
@ http://nextar.com/frontend/support.asp
to the right of the screen find:
download_top.gif Look for FREE software upgrades. Checkout our Download Center.
unfortunately ... there are none for your system at this time.
GPS Systems Support
Please find below the Nextar FREE Support updates:
The following is for firmware upgrade that fixes any known issues with the GPS operating system
*These updates are ONLY for the models listed. Attempting to apply them to a different model will damage the unit and void your warranty.*
Model#: P7
Model#: I4-BC
go to nextar.com for alotta help. tinkr
Jan 01, 2009 | Nextar Q4-04 Car GPS Receiver
GPS Logo
1,117 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
