Question about Dell Precision Workstation 670 PC Desktop
Dell Precision 670 Workstation possible VRM 0 issue
The computer stays powered, but drops the operating system and all the peripherals at will. The bays don't work, the monitor goes into "no DVI" signal, and the power button and HD LED remain illuminated. By simply leaving the computer alone, it will come back to life and show the Windows Login screen. If I press ctrl,alt,del and try to log in it may let me, but ultimately it just takes a dive at will. This all started last Thursday after some freaky storms here and I had no UPS. Please Help - Shaun Beauchamp (sbeauchamp@xactfluid.com)
    Genius:
  • 1,226 Answers
I can figure out what happen to your PC. However since that your pc keep slow ..If you can do open your pc and try to refix all the connection. the memory, hard drive, VGA card and other and test.. if this not solve then try to restore your original by reinstalling your windows operating system.
may this help,
melnavz
Posted on Jun 25, 2008
Dell precision 670 diagnostic lights y g y
http://www.dell.com/support/Manuals/us/en/19/Product/precision-470
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
http://www.ebay.com/itm/DELL-H2703-PRECISION-470-670-VRM-VOLTAGE-REGULATOR-MODULE-TH-0H2703-WS470-WS670-/380369885440
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
Dell workstation 670 reads bootmgr is missing
Your operating system software is corrupted or your hard drive is defective.
Oct 07, 2012 | Dell Precision Workstation 670 PC Desktop
Dell precision 470 work station processor fans over speed
Dell Support > Precision 470 Workstation Desktop PC > Users Guide,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/index.htm
Tools to Help Solve Problems > Diagnostic Lights,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/advtrbl.htm#wp1057482
"A possible VRM 0 has occurred"
VRM = Voltage Regulator Module
Here is what the motherboard looks like,
http://www.ebay.com/itm/DELL-PRECISION-Workstation-470-XC838-Motherboard-with-2GB-/140795014004?pt=Motherboards&hash=item20c8096b74
[Note* Posted for photo reference only. Not for advertising.
Besides, I do not see any VRM's plugged in. Means you get the motherboard only, and no VRM's. You need a VRM ]
What the Voltage Regulator Module looks like,
http://www.thebestpartinc.com/kg229.html
(Again, not for advertising. Click on the photo of the VRM to enlarge)
Notice that your motherboard has two VRM's. This is because there are two Processors.
Apparently the VRM for one of your Xeon processors is bad. (Z-on)
Since it states VRM -> 0, it is for the Processor 0, or in the number 1 processor socket.
What does a Voltage Regulator Module do for a Processor?
Regulates voltage.
A Processor MUST have a steady, 'clean' supply of voltage, AND it must be within the voltage range for the processor.
Since the motherboard uses an Intel E7525 motherboard chipset, it can support Intel Xeon processors, with up to an 800MegaHertz Front Side Bus. (800MHz FSB)
Looking at a typical Intel Xeon single-core processor, with an 800MHz FSB, let me show you it's voltage requirements,
1.287 to 1.400 (DC)
May be just a bad VRM.
However, I would also like you to look at the Electrolytic Capacitors on the motherboard. From what I have seen, those motherboards are notorious about having capacitors go bad.
Visual identification of bad Electrolytic Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
Regards,
joecoolvette
Jul 09, 2012 | Dell Computers & Internet
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
Is there a way to make sure both for my processes are working in my 670 Dell. I checked device manager it only registers one CPU. Two are installed with the extra VRM. No error messages are shown.
I would suggest going to the dell website and ensuring that all drivers are updates to their most current version. Also, flash the BIOS to the most current version if it is not showing the same version offered on the site.
Good Luck,
Jesse
Jan 11, 2010 | Dell Precision Workstation 670 PC Desktop
Noisy piece of "Dell" lol
That's a confusing description of the events charles.
Have you identified the cause of the original problem - the dead caps? Is Over Voltage a possibility - have you verified the stability of the PSU?
Apologies if I've misunderstood.
May 19, 2009 | Dell Precision Workstation 670 PC Desktop
Possible VRM 0 failure
69bf9f3.jpghi dear
Short for voltage regulator module, a small module that installs on a motherboard to regulate the voltage fed to the microprocessor. Nearly all motherboards have either a built-in voltage regulator or a VRM, the only difference being that the VRM is replaceable.
the cost is about $80 USD
oke
cropp
Mar 23, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
661 people viewed this question
Alun Cox
