Question about Danby DAC5020 Air Conditioner
Danby 12304D - no digital display
When we put our air condition in and plugged it in, same way as last 3 years, we heard a beep, but nothing lit up in the digital display. I checked the filter which was very dirty..cleaned and dried it. It's like there's no power, yet it beeps when we plug it in
  • fredder Jul 08, 2008
    Same exactly, plugged it in, filter was clean, heard a beep when power cord plugged in and NOTHING.
    I downloaded the manual, there is NOTHING abou a reset button, I am stumped
Sorry, my reply seems garbled.
The little connecting plug IS the problem.
The connection seems to be loose. I can plug the connector together and as I said Poof!, the a/c panel lights up properly and the a/c runs.
BUT when I shut it off and restart, NOTHING. I think I need to replace the connector, can I get one somewhere?
Thanks again El Barto
Posted on Oct 20, 2008
I have had intermittent running of this a/c. The little plug that you speak of seems to be the problem.
I have plugged the connectors together and poof! litle, action a/c. Turn it off then turn back on, NOTHING.
Can I get a repacement connector?
Thanks for the answer by the way!
There is a plug that detaches when you take the front cover off which you need to do when you put it in or take it out. It may still be unplugged if you forgot to reconnect when you re-installed. You will need to unscrew the screws on side of front cover and I think there is one behind the filter that you will also have to remove. Plug the plug in and it should be fine. Let me know if this solves the problem.
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Danby portable air conditioner will not turn on. Just beeps and the display will not power on. Emptied the water, no effect.
I have had the same problem with mine. Try to tape the small water container drawer shut. Restart the unit and see if the beeping is beepless.
Jul 26, 2011 | Danby DPAC120068 Air Conditioner
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
Randomly beeps for no reason at all. Can go 2 or 3 days then will start beeping. Day or night usually through the night.
hey i have the same problem. how log does it do it, how many beeps and how quicky. We have a danby also the 1.1 bought it about 3 years ago.
Aug 04, 2010 | Danby DMW753 Microwave Oven
Hello I saw the break alert light lit on my
Usually when th fluid level low light comes on, it is because the fluid is ging to the front calipers to fill the pistons that push the brake pads against the rotors. This is because the pads are worn down and probably need replacing.
As for the 3 beeps, it is not related to the brakes.
if it is 5 beeps, it is the air bag or pretensioner.
When the ignition is cycled (turned off and then on), the air bag indicator will remain lit for six seconds and then go out. If an SRS fault exists, the air bag indicator will then flash the two-digit LFC. The air bag indicator will flash the LFC five times, then it will remain illuminated for the rest of the key cycle. The RCM will also communicate the current and historical DTCs through the data link connector (DLC), using the scan tool. If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the GEM to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair.
Mar 02, 2010 | 2002 Ford Ranger Regular Cab
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
NO Display, POST or speaker beep
clean your cpu and put new heatsink compount
clean ram contact using student eraser
if you have postcard so you can judge problem
Oct 27, 2008 | Intel D845GLLY Motherboard
Danby DAC5020 Air Conditioner Logo
253 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
