Why does roper washer only has one hose?
Why does roper washer only has one hose, model rtw4000sw ?
It is a water inlet hose!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 25, 2008
    Problem Solver:
  • 9 Answers
One hose?? is it a drain hose or a water inlet hose,
Posted on Jun 24, 2008
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I have a roper Model # rtw4340sq0 that when on the "super" water level setting, just continues to fill ( and drain) when it gets to the rince cycle.
Sounds like the water is siphoning out of the drain hose.
Check the drain hose behind the washer to make sure it's higher then the high water level in the washer.
Aug 03, 2011 | Whirlpool Washing Machines
Roper washer will fill up with water and wont stop. What could be wrong?
The air hose from the tub to the pressure switch (inside the control panel) is either disconnected or plugged with debris. Open the control panel by removing 2 screws in the front corners and check for disconnected hose. Otherwise disconnect the hose and blow through it to see if it is plugged.
Jan 12, 2011 | Roper RAX4233PQ Top Load Washer
How do I find the water pump on a roper? Need to find out why the water won't drain.
disconnect the power supply then shut your water off unscrew your water hoses,then move washer out of it's space and look at the back panel proceed to unscrew the back panel look for hose connection that is water pump. If you overload washer with too much weight it will not drain also if you use too much soap it will cause a roper not to DRAIN this has happened to me check your drain line make sure it's properly installed ,take drain hose off and make sure it is clear you may have something stuck inside
Sep 26, 2010 | Roper RAX4233PQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
My washer keeps filling with water in the off position at first the cold water would barley run and know it runs slow all the time in the off position it's a roper washer
Your water inlet valve has probally failed.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available.
Apr 07, 2010 | Roper RTW4300SQ Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Roper washer wont Agitate
you have a bad watwer inlet valve but the agit. has nothing to do with the water unless you are not getting enough into the machine to start the agit cycle
Jul 29, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
