Question about HP Compaq Presario V2000 Notebook
Hard drive recovery
My motherboard on my laptop crashed. And, I don't want to spend the three hundred dollars or more to fix it. So, since the motherboard is fried. I no longer have the ability to receive power to run my laptop. So, I was wondering the best way to get my information off my hard drive? If anyone could please give me the necessary information I would be the most appreciative.
Sincerely, Chris Dunham
    Novelist:
  • 105 Answers
If you have another computer, you can just hook the hard drive up inside the other computer and transfer all the data from one drive to another. There is a chance you would need an adapter, but you should be able to get that if needed at a place that sells Computers. A shop that builds pc's on site is more likely to have the adapter, if you need one.
Sorry to hear that your motherboard died, that is a bummer indeed.
Hope this helps you.
Posted on Jun 23, 2008
  • 68 Answers
Sorry to say but you would have to spend probaly $100 at best buy
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
A disk read error occured
try this hold CTRL, ALT, DLT when it seems to reboot hold CTRL bring up a menu press safe mode after windows starts go to windows start menu go to run cmd type msconfig press the first one start windows normal
Feb 01, 2013 | Dell Inspiron 2200 Notebook
I cant open or format my hard disc
Try this method
Uninstall the hard disk
Connect it to the other system/laptop as external drive
Install data recovery software on system/laptop
Scan the external drive for recovery options available
Save the data you want to recover
You can download a good data recovery software from http://www.windowsdatarecovery.com/
Aug 16, 2011 | Computers & Internet
My seagate drive (Free Agent Go) is not showing up in My Computer. it keeps on blinking. i have inserted it to all three of my USB ports and all have the same result. i tried attaching a different cable to...
ya clicking is VERY bad sign and it is most likely fried. If you have to buy another one goto a computer store and buy a regular laptop hard drive and an external case for it then ask the kid to put it together for you.(they should do this, if not shop somewhere else) The reason is because the laptop hd is designed to resist more abuse as they tend to get bounced around inside of laptops that get dropped, tossed, stepped on, etc. i hope you did not lose alot of valuable and/or sentimental data and good luck:)
Jul 26, 2011 | Seagate Computers & Internet
The hard drive crashed will not start
If the hard drive have crashed meaning that the hard drive itself is damaged, then your solution is to replace a new harddrive. If you do have a recovery disc already made, or one is provided then you will have to use that disc once the hard drive is replaced with the new one, and follow the procedure to reinstalled the operating system. If the original hard drive had crash and does no work anymore (where the bios/computer cannot detect it) and you have important data that you would like to retrive, there are places such as office depot, bestbuy, where they can help you send it to a recovery file center to recover files from your damaged hard drive. Do not attemp to fix or open a damaged harddrive, you can forever damage the files on the cyclinder disc. 2) Now if your harddrive crash in term as windows just crashing and you cannot get into your operating system and the bios is still able to detect the hard drive, and it's giving you a error message, then you will only need to reinstall, or do a windows recovery through your recovery disc, If you do not have a recovery or made the disc, then you will need to buy a new operating system software. If you computer does not start meaning no display on the screen at all, then please replay back. That is a different story.
Feb 06, 2011 | Acer Aspire 7720-6569 Notebook
How to extact the data off the Seagate Barracuda 7200.10 320GB HD
if its your motherboard that crashed then ther is no problem with your hard disk. connect your hard disk to any other computer and you can access all the files in it.
if it is your harddsik that crashed then try recovery utilities like western digital data storege manger or any other disk recovery tool available for free. if still it fails then you can recover your data if you hand over your hard disk to the nearest service centre. but recover from a hard disk only if its very valuable. thay will charge you per MB of data recovered
Jul 04, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Need to recover the computer, back to factoru settings
Call sony, the disk is 12 bucks. I had this problem after my hard drive crashed. Be careful though, because I replaced the hard drive and it would not recognize the disk after that. Sony wanted me to pay 100 dollars to fix it.
May 07, 2009 | Sony VAIO PCG-K23 Notebook
Re-format
If you started a format, but it didn't complete, you pretty much cleaned out the hard drive.  go to start>right click my computer and click manage.  On the left hand side under storage, you will see disk management.  Click on that.  Now before we continue, I will tell you that if there is anything important on your hard drive....DO NOT CONTINUE!!!  As what I am about to tell you will completely erasse everything with NO chance of recovery...at least not without spending hundreds of dollars.  Find your external hard drive on that list on the bottom.  Right click...delete partition.  Then right click and create partition.  Then right click and select format.  That should be it in a nutshell.  Hope it helps.  Please rate!
Feb 27, 2009 | Western Digital My Book Essential Edition...
Drive crashed and is showing unallocated space
You can use a program like Data Recovery Wizard which is able to recover the file system and files of a partition which has been reformatted. I believe they have a trial you can download that may do the job.
Otherwise the program costs several hundred dollars, and it would be better to take it to a PC shop for drive recovery.
Know that I have not used the program, nor the company, and of course do not endorse them - however, this program would seem to be your fix. As I cannot speak to the reliability of that particular program, I can only say to be careful and hopefully you can recover everything you need.
(please Rate if it works out for you!)
Dec 14, 2008 | Maxtor DiamondMax 10 200 GB Hard Drive
Dead hard drive
ya
just change the HDD main CKT with compatible board
HDD spin or running is mainly depends power supply and ckt assemly and motar ,other parts of data storage is just dead without ckt,if he can recover the data-it is not big expencive,it wants some basic knowledge and technical experience,the service charge is depends the valuable of data and difficult in recovery and how much skills is used, just remember- he selling his experience and knoledge for you,
Mar 06, 2008 | Samsung (SP0822N) 80 GB Hard Drive
HP Compaq Presario V2000 Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
