Back to:
Tags:
Mitsubishi VS-50605 50 in. Rear Projection Television
Lightning strike
posted by wekindle on Jun 23, 2008
i had lightning strike the tree behind my house and it blew my tv. the light stays on when you plug it in but the tv wont do nothing. So i bought a service manual and it says if the green light dont blink when you hold the device and menue button in that the microprocessor is not functioning properly. Is this true? or am I missing something? I tested all the fuses and they check out. Do i need to try something else. How much is a microprocessor and where do i get one. PLEASE HELP!!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2008
Not Rated (0)
scrodamoon
Rank:Guru Guru
Rating: 85%, 189 votes
This model is famous for capacitors being bad in the low voltage regulators on the signal board. Also has been known for cold solder connections in the power supply to the convergence IC. I don't have my notes at home but I belive that model only uses one IC for convergence, STK393-570. You cant see it from the back because of it being hidden by its heat sink.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on lightning strike:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
Mitsubishi VS-50605 50 in. Rear Projection...
Thanks big Ir... would you think that the traces would be...
Where can i get a service manual for this set. I'm pretty...
was watching the set the screen went dark then back to...
my tv screen is rolling when you turn on the tv....someone...
lighty fuzy picture some channels better than some
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
