Question about Garmin StreetPilot c340 GPS Receiver
Garmin won't turn on anymore
I've had it for two years and it's been working OK so far. Now it won't turn on at all. Any ways to diagnose the issue?
Hey ZPERACHA--try taking a tooth brush and swipping the contacts on the main body where it snaps to the mount, then charg overnight!! good luck! jim
Posted on Jun 24, 2008
AC on 1999 Oldsmobile intrigue not working correctly.
the air feels hot ( compressed) because the ac compressor is not working
you say that occasionally it kicks in and then the air is cold
that could be either a climate control module , thermostat compressor relay problem but which ever way you look at it it will cost cash
the best way is to have the problem properly diagnosed by an accredited ac specialist shop and get a quote and then decide on the fix
Apr 21, 2017 | 1999 Oldsmobile Intrigue
Garmin forerunner 205 will not stay OFF and none of the buttons respond.
Yes you can restore your data from the TC after a hard reset. You have to go thtrough the setup menu like chose which language etc first.
Well I have exactly the same problem as you and a hard reset did not work either ...
Upgrading / downgrading the firmware also did not work.... the thing keeps on switching itself on regardless....
Do you have found out something more in the mean time?
Feb 16, 2012 | Garmin Forerunner 205 GPS Receiver
Why does my 91 ford econoline over heat when I turn my heat on?
I've been working a similar issue with a friends truck. When the heater blower motor is off the engine temperature gauge reads normal in the middle. But when you turn the blower motor on the gauge goes way up to the top. The engine isn't really overheating. There is an electrical problem that when you turn the blower on it is affecting the temperature gauge and making it go all the way up off-scale. So far we've found that the blower motor speed control resistor is bad. We replaced that and the speed control works now, except for the low speed setting. I suspect there is a bad ground somewhere and the bottom end of the resistor element isn't grounded anymore. As such too much current is going through the ground in the dash, which is affecting the gauge.
Feb 06, 2012 | 1991 Ford Econoline
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
I have a Garmin Nuvi 255. I have had it for about a year. It has worked fine until we headed to Tulsa, OK from Columbus, OH. Most of the way there, it was fine, but about half an hour to an hour after we...
There is a reset button on the 255 i on the bottom right edge as the unit faces you, and is underneath the serial number sticker. You'll either have to peel the sticker up for access or poke a hole through it. This should get you going again. I am am also attaching a link to garmin support. Let me know how you made out. Thanks for using FixYa
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 16, 2011 | Garmin Nuvi 255 GPS Receiver
My GARMIN nuvi won't turn on
you need to provide more info. Won't turn on is like saying "you have not slid the on switch to on", or you have not charged the battery, or you don't have power to it. What have you done so far, and has it ever turned on and worked? If it has, when and what happned to not operate anymore?
Mar 30, 2010 | Garmin nuvi 205 GPS Receiver
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
Jun 12, 2009 | Viking 42 in Built In Professional...
My Garmin c550 will not come on anymore. The screeen is black
Check the 12v power cord to make sure its still powering/charging the unit. Usually they have a light on them that will show if its receiving power or not. You can also unscrew the tip of those things (on most cables) and check the fuse to see if its blown. If its not lighting up and the fuse on the cable is ok check the one in your truck to see if it needs replacing.
If the cable is not the issue then the GPS is probably dead. If its not under warranty the flat rate repair fee from Garmin is $200
http://www8.garmin.com/support/outofwarranty.html
Jan 18, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin GPS-V freezes up
The update from Garmin seems to have cured the problem!! All I did was the reload.
Thanks velomaster!
I've had my Garmin GPS V for almost four years and loved it ... until the dreaded "black line" showed up. I considered replacing the unit but couldn't find anything that would give me the features the GPS V gave me (elevation, ground speed, grade change) and I didn't need a color screen display as an alternative. I'd even bid on a few replacement units on ebay. I was just about ready to bite the bullet, send it in to Garmin and swallow the $125 rebuilt charge when I ran across this thread. After the update it hasn't locked up and as a bonus I have more detail than I had before!
http://www8.garmin.com/products/webupdater/
If you have a GPS V you really do need to do this.
Mar 17, 2008 | GPS
Garmin StreetPilot c340 GPS Receiver Logo
27 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
