HP PSC 1410v All-in-One Printer Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have problem with Scanner. Unable to scan for window 7. Printer is work good.
Level 3:
  • HP Master 7,733 Answers
  • Posted on Nov 27, 2010
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1863809
Points
21487
After getting Windows 7 I can't use the scanner button on my F340 aqll in one and I can't figureout the scanner feature on Windows 7
It sounds like you installed the generic OS driver from Windows 7. This driver only works for the printer. (Alternatively, you do not have the monitor program running or the destinations set in the HP software.)
If you plugged in the data cable before installing the HP software, uninstall the printer (Devices and Printers) then disconnect the data cable (USB). Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128309& and select your Win7 version (32- or 64-bit). Then click Next. Expand the section marked driver and download the Full Software. Install the software. Connect the data cable when prompted to do so. (Try a new USB cable since scanning requires bi-directional communication with the printer and can fail when the printer works). Avoid using a USB hub or print server.
If you do have the HP software installed, check that the monitor program is running (Start > Control Panel > System and Security > Adminstrative Tools > Component Services > Services.) The line for the HP monitor should say started. You may need to download and install the patches or the diagnostic utility from the above site to find a specific problem with the Win7 installation.
Next launch the HP software and attempt to scan from the computer. Next use the settings that give good results to program the defaults for the scan destination buttons. Now try to use the scan buttons on the all-in-one.
Once you have the HP drivers for both the printer and the scanner installed, the Windows 7 Fax and Scan and Paint programs should let you successfully scan from the computer. (New scan for fax and scan. File > Import from Camera or Scanner > New Scan for Paint.)
I hope this helps.
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
1helpful
What is the process to save a document or picture scanned with my HP Deskjet F4280? I am using Microsoft Windows 7. I am unable to install any HP software for this printer/scanner while using Windows 7.
There is no need to install any software for scanning from Windows 7 computer.
It's very easy
On computer click "Start" (windows icon)
click "All Programs"
click "Windows Fax and Scan"
click "Scan" and complete the scan as per on-screen instructions there
Make sure printer is turned on and connected to computer through usb cable properly.
3helpful
3answers
Black lines on scans and prints HP 2727nf
File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
My scanner will not work,,,it says it has no scanner option refer to device documentation...I have used the scanner in the past so do not understand why it does not work.
what operating system are you on? If using windows 7 or Vista .use windows fax and scan. It can be found at start menu>all programs>windows fax and scan. Load scanner and its off to the races. Good Luck!
How to use a scanner?
What OS do you have? If you have a Windows XP or 2000, download and install the full-featured software and use the HP software to scan.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=306895&
If you have Vista and Win 7, HP doesn't have a full-software driver package. You will be using the drivers built into the OS.
For Vista, you can scan using the Windows Photo Gallery (File, Import from Scanner) or Paint (File, From Scanner or Camera) and with some versions Windows Fax and Scan (New Scan, File, Scan).
If you have Windows 7, Paint and Windows Fax and Scan will let you access the images/documents on the scanner.
In all cases, a good cable and ports will make scanning much less frustrating.
I hope this helps.
(alternatively, you could get third party software for Vista or 7. PaperPort is one example)
Scanner not working
The scanning driver is for old OS, hence its not compatible with win 7.
Please click here to know and fix the scanning feature with Window 7 operating system.
Regards,
Riztech
Unable to open Epson Scan in 4490
try to uninstall and reinstall your printer software
k24674
Grand Canyon Tech
Grand Canyon Tech
