Question about Tivo Series2 TCD649080 Video Recorder
Tivo to connect to my verizon fios cable box
How can used and integrate tivo with my verizon fios cable
  • inday001 Jun 23, 2008
    what do i need to know in order that my tivo series2 can use verizon fios cable as its service
  • 21 Answers
You need the dvr.
Posted on Dec 13, 2008
Wont connect to verizon dvr box, its connected to the video out cable and the fios tv cable.
Make sure that the dvr is not outputting a HD signal to your set - if it is, your set will not work unless you change the signal to 480 from the HD setting.
Dec 11, 2015 | Televison & Video
I AM CONNECTED TO FIOS VERIZON. MEDIUM HIGH SPEED. IS THERE A WAY TO GET NETFLIX HOOKUP THRU THE WIRELESS ROUTER I HAVE FROM VERIZON to my tv..
There are multiple ways to stream Netflix over a high speed internet connection. You will need a device to run the Netflix streaming - your choices are Playstation3, Wii, Xbox, Tivo Premiere, or a Roku box. You could potentially use a computer connected to your TV to stream it as well, but the computer would need the appropriate outputs to hook up to your TV.
Mar 15, 2011 | Mitsubishi WD-60737 60 in. HDTV
The prior owner of my house had verizon fios, the fios wiring is in basement as well as junction box for telephone (gray box) I have unplugged the ac power plug to the fios as I am not using their service....
you're better off calling verizon to remove it.
but no, it uses your power ... not anything from the street. fiber optic cable is made of glass and does not conduct electricity.
Jan 22, 2011 | Lands Phones
I got a hd box and the channels keep cuttin out
Hello, I actually install HD boxes for Verizon Fios. If your video signal is too low, you will notice "Pixellation" (Those weird square boxes that come and go) and in some cases, you will not even be able to receive some channels at all. HD channels use much more bandwidth than standard definition channels. The good news....there's a fix. If you use standard cable (Not Fios) you can buy a signal booster. These can be purchased at best buy, Radio Shack, etc. It is a powered device that plugs into an outlet (110v) You take your cable company's input or "Feed" run it into the booster, connect the power, and the run a coax cable out of the booster and into your splitter. Assuming all of your cabling is up to par, this will fix your problem. If you have Verizon Fios, you must call and have us come out as our tv service uses "Moca" and cannot be boosted with a store bought unit. I hope this helps.
Jan 03, 2011 | Televison & Video
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Download from FiOS DVR (Motorola Box) USB port is disabled by Verizon to preclude lawsuits by content providers and Movie Industry, but the ability is contained in the box.. I want to download and save...
If you have audio/video connections out of the dvr then that will work , otherwise use a hdmi to a/v converter with red white and yellow connection and use a dvd recorder.
Jul 22, 2017 | Motorola Televison & Video
I already have verizon internet"fios' how ever i want to purchas cable for my hd tv
Usually Verizon can offer HD TV over the same FIOS cable. If you call them, they can connect it to your TV for you.
If you call the cable company they can probably set up cable for you. The two shouldn't interfere with each other.
Jan 25, 2009 | Computers & Internet
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
Tivo Series2  TCD649080 Video Recorder Logo
727 people viewed this question
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
