I have not specifically worked on this make/model of computer.
Technically, you cannot reset this ... I think what you are asking is how can your modify the settings.
Typically one would press F2 or F8 or F11 to enter the setup during the boot process. It may be a
different F key, it should flash on the screen when you boot.
You could disconnect the battery back up if you can locate it. ..This will remove any custom setting, but will not let you get back in to change it unless you find the correct F key to press.
On the other hand ... there are no more than 12 F keys. You should be able to find the proper one.
If this doesn't work, you should go to
www.fujitsy.com/support for assistance.
Thanks for visiting today.
