Same question DMI then freezes
It does say successful but then hangs. This happened after a thunderstorm and there is no hard drive.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
Does the pc say "no hard drive?" is the hard drive there but not detected?
Posted on Jun 23, 2008
  • vanessa helman
    vanessa helman Jun 23, 2008
    do you have winows vista, XP, mac, or linux?
  • vanessa helman
    I am assuming that your HDD was working fine with SATA and Windows loaded
    until this issue...you may need to re-install windows or do a repair and try to reload your SATA/Raid drivers
    or....
    I'd advise that you do a whole system hardware troubleshooting...STEP BY STEP and don't skip anything just because you "have done it before".
    That's about the only way your going to sort the problem out & stop guessing.
    Hope this helps ps-post back with your results & if you need more help be sure to post the complete
    specs (make, model etc.) of ALL components installed in your system.
Computers comes on and it goes to verifying dmi pool data and comes back with error msg....or after its been unplug for awhile it goes back to normal but after awhile it freezes up and then when hard reset...
During the verifying dmi pool data stage of boot, the Motherboard is trying to 'poll' the devices in your PC. This is governed by the BIOS settings in the CMOS chip. It is possible to have a defective CMOS chip, but rare. It is possible to have invalid or corrupted BIOS data in the CMOS chip--which can be cleared to a 'default' state. You stated that if it is unplugged for a time, that it will 'go back to normal', the corruption is being reset. If your BIOS is set to be 'shadowed into memory' for faster loading, then Disable that feature and see if the problem is corrected.
You would need to open the Tower and locate the Motherboard Model (like P5SD2-VM) then look on the internet for the Manual for that model and see if there are any BIOS settings for the 'shadowing' of the BIOS.
This problem can also occur if there are SATA drives in the Tower and 1 or more are not being detected, (depending on the BIOS MFR,) this happens to older boards with SATA ports, much more than late model ones; so while you have that side-panel off, remove and re-connect all of your Power and Data cables to the Hard drives and the Optical drives, (CD/DVD.)
Jul 31, 2011 | Acer Aspire AM1610-U1201A PC Desktop
When system power on after checking the memory my system hang on the varifying DMI pool data........
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 08, 2010 | MSI MS-6163 Pro Motherboard
Acer AM1100 hanging up on DMI update
Restart.
Enter BIOS SETUP.
Use "Load Factory Default Settings".
Reset the boot-order to floppy/CD/Disk0.
Save/Exit.
This will force a "full" DMI update.
Watch for the computer to spin the floppy,
and then spin the CD, looking for "boot" records.
If it does, then the DMI update has _COMPLETED_ and the "boot" process is starting.
Feb 03, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
This issue can be caused by any of the below reasons.
-Corrupt boot files on the computer.
-Settings for hard disk drive are not correct.
-Floppy diskette or CD in computer causing issue.
-Boot devices not set properly.
-BIOS corrupt or misc. setting not set properly.
-Connections loose or disconnected.
-Bad Hard disk drive or other bad hardware.
Solution:
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:\> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue attempt to reset the BIOS / CMOS settings to the factory or default settings.
If the computer has been recently moved or new hardware has been installed in the computer it is possible that a connection may be loose or even disconnected. Verify that the hard disk drive, floppy and CD-ROM cables are properly connected.
Bad hard disk drive or other bad hardware
If you computer continues to freeze at the DMI message after attempting all of the above recommendations it is possible that the computer may be freezing because of a bad hard disk drive or other bad hardware in the computer.
Before replacing any hardware we first recommend you attempt to erase everything on the hard drive and start over.
If you're unable to get to the point of re-installing the operating system it's likely your computer has a hardware issue and it's suggested that the hard drive be replaced. If that doesn't resolve the issue then have the motherboard replaced.
Oct 20, 2009 | E-Machines eMachines Desktop PC
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Acer Aspire AM3100-U3202A ''hard drive'' will not boot up
That could be a hardware failure of some sort, or because you added a new hardware device. The "DMI pool" code has nothing to do with Windows, but is part of Plug and Play. Windows has not even loaded yet. It is the System Board BIOS startup code checking the hardware configuration, and setting system board resources for Plug and Play to use. Go in to the system board BIOS (normally DEL key when first powering on) Look in the PnP or PCI Configuration section, for an entry "Reset Configuration Data. It will show Disabled. Change it to Enabled, and save the new configuration and reboot. BIOS will set it back to Disable after it clears the DMI data and rebuilds it. The first time through, it will take a long time, but after that it should not hang. Unless there is a hardware problem with one of the adapters on the system board or PCI bus.
I have seen CD-Rom drives cause this hang, if there is a CD in the drive. So make sure there are no CD's in the drives when you start up.
Apr 01, 2009 | Acer Computers & Internet
Pc will not boot
so....just what is the rest of the question?
Sep 10, 2008 | Computers & Internet
Hard drive and DMI issue
No, the DMI issue will remain. It has to do with the recovery operating system being linked to the machine's serial number. Purchase an operating system disc and that will take care of it. The only catch is that you will need to install some drivers for your machine after the install. All the drivers can be found at Toshiba's support site. Keep in mind that the hard drive not booting may be a hard drive failure in which the drive may need replaced, but just a new hard drive will not solve the DMI issue.
Aug 20, 2008 | Toshiba Satellite A25-S307 Notebook
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
