Question about Philips 27PT6441 27" TV
Philips 27PT6441 POWER LIGHT BLINKS WHEN TURNED ON BUT NO PICTURE, FUSE GOOD. cAN YOU HELP?
  • 5 more comments
  • Caleb234 Jun 24, 2008
    Located in ohio, noticed that discussions focused on a thermistor that may be faulty. is this the case?
  • Anonymous Jul 06, 2008
    Well my tv continues to turn off after i turn it on and it's really frustrating help please!!
  • Anonymous Jul 14, 2008
    Problem: green light on lower left of tv blinks when power button is pushed but no picture.
    Please respond.
  • mommaleah Jul 14, 2008
    Green light blinks on bottom left of tv when power switch is pushed, but there is no picture
  • izzodub420 Nov 01, 2008
    green lite blinks 3 times on my tv but wont show any picture
  • tycer18 Feb 17, 2009
    My philips actually seems to have lasted longer than some others, but nonetheless the same problem has occurred. 1,2,3 with the green flashing light, what can I do to fix the problem?
  • 2BME Feb 25, 2009
    green light flashes when turned on, I can hear the channel for a couple of seconds but can not see anything due to white lines. Any help on what this is and the cost to fix?
  • 48 Answers
This is a very common problem on this model. Where are you located ?
Posted on Jun 24, 2008
I am having the same problem with my t.v. It is a phillips model 27PT6441 power light blinks repeatedly when turned on and no picture? Can you help?
Probably some power supply trouble (could also be elsewhere).
Check for:
- inflated or blown electrolytic capacitors - replace these
- bad solder connections on ANY of the components (resistors, coils, diodes, transistors, ICs, etc. - if anything has been heating up, the circuit board wil look somewhat darker around those components) - resolder bad connections
- burnt our resistors or any other component (this might require some measuring, perhaps a schematic if any components are damaged in such a way that makes it impossible to read the type or value of the component).
-also, if a capacitor is niether inflated nor blown up, it might still be dried up even if it looks good, but, in such a case, it will tend to heat up. Check this by turning the TV on, let it blink for a minute or so, turn the power off and quickly DISCONNECT FROM POWER OUTLET, then see if any of the capacitors has been heating up by touching its top with a finger (you obviously need to do this with the cover removed and need to BE VERY VERY CAREFUL, there may still be high voltage present, so don't touch anything on the picture tube neck, and it's not a bad idea to put latex gloves on your hands to insulate them when you touch the capacitors or anything else).
Hope you can find out what it is, and please, do take care, i don't want to be held responsible for people getting electrocuted as a result of my suggestions.
regards
3rq8 (Triarcuate)
Aug 01, 2009 | Philips 27PT6441 27" TV
Don't know what size and amps fuse to use for T4E250V (#on the fuse)
4 amp slow blow -- any fuse with those characteristics will suffice.
May 30, 2009 | Philips 27PT6441 27" TV
Tv problem
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions.
Aug 05, 2008 | Philips 27PT6441 27" TV
Philips power green blinks and no picture
Jul 07, 2008 | Philips 27PT6441 27" TV
No sound or picture just blinking green light
That sounds like a power supply Issue, Unless you have the full service INfo and proper equipment its best to call a repair tech for your model as an isolation transformer is needed to saefly diagnose the power supplies.
Jun 06, 2008 | Philips Magnavox 27MS343S 27" TV
Philips tv
Try rebooting it. If it does not work, then looks like your TV needs service.
May 18, 2008 | Philips 27PT6441 27" TV
Philips 27PT6441/37
May 03, 2008 | Philips 27PT6441 27" TV
No power
Apr 25, 2008 | Philips 27PT6441 27" TV
Philips TV
Please PM me privately to tell you how to fix this problem... it's a bit lengthy.
Jan 22, 2008 | Philips 27PT6441 27" TV
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
Jun 26, 2007 | Philips 27PT6441 27" TV
Philips 27PT6441 27" TV Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
