Our Harmon Kardon AVR 7200 Audio/Video Receiver does not come on when plugged into the outlet, even when the main power button is depressed. Some articles have suggested that it may be the power supply. The nearest authoried repair is approximately 100 miles away.
  • gmhater Jun 23, 2008
    To the experts that e-mailed me, Thank you. But how do I review all of the posted solutions?
    Thank you to all who e-mailed me. I guess that there is a road trip in my husband's future and to Largo, Fl of all places.
    Guru:
  • 859 Answers
Unplug your unit. Remove the top cover by taking out the screws. Then pull up on the back and slid it out toward the rear.
Where the cord wires pass through the back and into the circuit board you'll see a power fuse somewhere near that location. Look carefully with a small flashlight to see if the small wire inside the fuse if intact or not. If you're not certain carefully lift up one end of the fuse until it releases and then lift the entire fuse out. Hold it up against a light. If you have a meter check to see if there is any or no resistance of the fuse. If there isn't any or you see the remains of a blown wire/fuse just replace it with one exactly the same. Markings are on the silver tone ends of the fuse.
The fuse is capable of not blowing but elements of your primary power supply can fail. Look for burn marks along paths of components on the board near the power transformer and little chips that start with 'ic'. Also, look at the transformer for a burn mark or drippings of varnish or electrolyte. If any of those conditions exist you would have to replace them all and assume they are all compromised. If you can't do this, now is the time to find a repair shop or electronics guru or friend/neighbor/chamber of commerce who can recommend one to you. If you are under warranty the choice to proceed or return it is strictly up to you.
Regards,
Worldvet
Posted on Jun 24, 2008
  • 6,487 Answers
Yes that's really a power supply issue and you ned to have it replace so just take it to the nearest repair center near you to replace it..
Good luck.......
Posted on Jun 23, 2008
    President:
  • 2,712 Answers
It does seem a problem with the power supply or a couple faulty components. Unfortunately, if you have no experience with electronics, this could be a tough ask. If your unit is not under warranty, then any local repair shop may be able to fix this for you. BUt if it is under warranty, then it is best to contact your point of purchase or the manufacturer directly..
    Master:
  • 848 Answers
The high voltage might have passed into the receiver so it is able to on itself even if you plug to the outlet
  • 197 Answers
Well...that's not too cool...it's either the power supply, a fuse, or something in the control board...you feeling handy enough to tackle this one?
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
How do you hook up a power amp to harmon kardon 240 receiver
If your receiver has preamp outputs, you should be able to plug and play
Jan 27, 2013 | Harman Kardon AVR 240 Receiver
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Harmon Kardon AVR 235 no sound
Ensure that your speakers are connected to the terminals that you have your speaker selector switch turned to.
Then check that you have your device, whether it be a CD or DVD player, or turntable, plugged into the correct input and that you also have the correct input selected on the receiver.
Dec 29, 2009 | Harman Kardon AVR 235 Receiver
Harmon Kardon AVR 5
Assuming that the system is properly installed and was working ok before, the problem is usually a blown output amplifier in one channel and the receiver disconnects the speakers to avoid damaging them. In this case, professional repair is required.
Nov 15, 2009 | Harman Kardon AVR 5 Receiver
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
 Grubhead
Grubhead
