Question about Sharp 25L-S100 25" TV
Pscan split screen
Whenever we watch a DVD this TV shows a the same image side by side on the screen with a yellow box in the middle that reads P-scan. This dvd player worked fine on our other TV. Any ideas? We have also lost the remote. Will we need to get a universal to fix this?
  • kweenmab Jun 24, 2008
    Thanks for suggesting it might be the player. Apparently the TV is not progressive scan compatable. I just had to flip the switch. Sorry for the trouble.
  • Neal Brown May 11, 2010
    What model of DVD player do you have?
    The remote question - yes you'll need to get a universal because the TV is not sold at retail any longer and so there is very little to no chance that Sharp would still have a remote to sell.
    Have you checked the manual on the DVD player to see if it talks about what you are seeing?
techman
  • 3130 Answers
SOURCE: Can't Get Any TV picture on mySharp 27DV-S100 TV-VCR-DVD combo
open back up the set and look closly at all of the plug connections and cables as you might not have pulled one out all the way but may have in inadvertantly pulled on a cable of one of them and pulled one out have way or just a little. My freind it happens to the professionals all the time. Make sure you check all the plugs on the VCR as well as the tv that they are instraight and flush. Good Luck Ps Please dont forget to rate this.
Posted on Oct 15, 2006
snakehead
  • 1074 Answers
SOURCE: fuzzy white lines
YOUR tv DEVELOP a problem in the video ocillator or the tunner section have this set check by a qualified tech.to solve your problem good luck.any more contact nicodhem@yahoo.com i hope by now you have gotten your set fixed the repairs will cost you about between $50.00.to $200.00 good luck.
Posted on Mar 26, 2007
coolvicky
SOURCE: Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Posted on Aug 04, 2007
SOURCE: volume does not work.
Good day.
You are possibly right. Audio circuit might got affected. I would like to suggest likewise that you check also if the speaker is busted, the audio IC and if it receives supply from the flyback.
chris
Posted on Mar 29, 2008
SOURCE: set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Posted on Apr 22, 2008
Whenever I try to watch a DVD the screen splits and a message reads "PSCAN"
You need to do one of two things:
1) Look at the back of the DVD player for a switch that is labeled with " PROGRESSIVE SCAN', you need to set it to OFF (since you are using Composite Video jack (Yellow RCA jack) output of the DVD to feed your TV, but the DVD player is set to PROGRESSIVE scan mode, taht is why you are seeing "PSCAN).
2) Use the component video input/output instead by using 5-wire cable set (Red, Blue, Green for video, and White and RED for audio).
Sep 03, 2011 | Sanyo Televison & Video
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
When i load a DVD, I get a split screen and a large PSCAN!
Probably fix it with the remote. Look up progressive scan in your manual, and turn it off.
Apr 29, 2010 | Sceptre X240BV-FHD LCD TV
PSCAN warning and screen is split in two
hotpoint first edition hvl211 has 3 flashing lights how do u stop this is there a reset you can do
Jan 05, 2010 | Acoustic Solutions Audio Players &...
I have a mvd 4544 dvd combo hooked it up to my new vizio tv and now i get a split screen with a yellow pscan box in the middle.
Do you have the dvd player set up as progressive scan? Most likely this is a settings issue. How are you connecting the dvd player to the tv as in what type of connection? Once I have more information I can assist you further.
Thank you,
Lee
Dec 11, 2009 | Memorex MVD2022 DVD Player
The dvd player displays a big yellow box in the middle of the screen with PSCAN with an exclamation point above it. Also the screen is showing the right side with a wide split between them. This is the...
I found the manual for this dvd player online. There is a switch on the back of the player. PSCAN is Progressive Scan. Some TV's are not compatible with this function so the switch must be turned off. This worked and I was watching a dvd last night!
Nov 03, 2009 | Memorex MVD2042 DVD Player
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
My memorex dvd shows a split yellow pscan sing
On most of the Models there is a Pscan button on the back of the unit in the middle. just turn that off and you should be good to go.
Aug 22, 2009 | Memorex MVD4544 DVD Recorder/VCR
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Aug 21, 2009 | JVC HR-XVC18B DVD Player/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Sharp 25L-S100 25" TV Logo
41 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
