Question about Acer Aspire 3002LCi Notebook
Dvd drive drive wont work will any drive work in 3003 laptop Want to replace Acer Aspire DVD rom Drive
    Sergeant:
    Champion:
  • 271 Answers
Normally disk drives doesn't need drivers...it will get installed not to the OS but to the BIOS...else you have a problem with the drive...you can find it out in the bios menu...
Need More to Know?..then please reply
____________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Posted on Sep 06, 2008
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
Acer aspire 3690, my cd-rom will play movies, audio and some old games can be read but mostly refuses to read most of my game disks now, any ideas??
Try an external DVD drive that you can connect to your USB port. The drive you have in the laptop either has a dirty laser lens, which you can carefully clean with a "Q" and alcohol, or the laser itself may be going out. The drive can be replaced. You mentioned you have a cd-rom. If you can play movies (DVD) it is more likely a DVD drive instead of a cd-rom. CD-ROMs can only read data or music.
Nov 19, 2010 | Acer Aspire 3690-2196 Notebook
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
Apr 17, 2010 | Acer Aspire 5315 Notebook
My dvd and cd rom does not pick up dvd but only cd's
Is it really a DVD drive? DVD drives can pick both with ease but a CD drive cannot pick DVD's.
Nov 29, 2009 | Acer TravelMate 512DX Notebook
Cd/dvd-rom drive E: not detected
plz check in the bios the cd rom is enable, then check the datacables try with a new data cable
Jun 19, 2009 | Acer Aspire 5315-2153 Notebook
Acer aspire can't find the dvd to play cd's
In the device manager, select the DVD ROM and UNINSTALL / REMOVE the device.  Restart Windows . . . did this work?  If not, boot into your CMOS and see if the drive is being detected by the motherboard... if yes, look further and make sure the settings for the drive are correct. Make sure that all IDE interfaces are enabled in the CMOS settings (both)
Dec 13, 2008 | Acer Aspire 5315 Notebook
Laptop drive
dear sie
computer acer aspire 1360 pc dvd drive dease not book
dvd driver stop working c drive was over laoded and the computer whent in to disk clean and deletelte the driver for the dvd rom i can no longer play cd dvd or use the crw or dvd RW ASPIRE 1360 2.8GHZ
PLEASE CAN YUO HELP LOST THE DISK THAT CAM WITH THE MACINE
YUORs garyfifiled@talktalk .net
Jul 28, 2008 | Acer Aspire 1360 Notebook
DVD-RW optical drive
is your dvd detected in bios ?
if yes, it's windows issue.
follow the step by step from this link:
http://support.microsoft.com/kb/314060
Feb 29, 2008 | Acer Aspire 3003WLCi Notebook
Dvd drive
its u r dvd drive laser eye problem.replace u r dvd drive
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 3002LCi Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
