Question about Amana ABB1927DE Bottom Freezer Refrigerator
Quit working I replaced the thermostat nd it started working,but 36 hours later when I went to get an ice cube, I noticed it was a little watery. I turned it up to coldest, but when I got home this evening, it was melted again. Now, the temperature is 45. any suggestions?
  • 848 Answers
Then there may be some voltage problem
Posted on Jun 25, 2008
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Uline bi98 ice maker
follow this test. and fix it. use the multimeter.God bless you
If the ice cubes have watery or hollow centers, the icemaker is getting too little water. Alternately, excess water or ice in the bin is caused by too much water. Turn the water supply screw to adjust. If adjustment does not remedy the problem, you may need to service the water inlet valve (see below).
If you suspect trouble with the motor or switcy in an icemaker, use a multimeter to test the component. If the motor or switches test faulty, replace either the bad components or the entire module. If not, you may only need to replace the thermostat (see below)
Oct 28, 2013 | Kitchen Appliances - Others
For the past month the ice maker is not dispensing ice cubes. The water supply valve is turned on, there is no kinks in the water source line and the ice maker is turned on. I ran out of ideas. Do you have...
The water tube that supplies water to the ice maker is possibly frozen up.
The way to check this is to empty all food out of both sections and store alsewhere, then turn off and unplug the unit. Wait for 24 to 36 hours with the doors partially open to allow all the ice to melt.
Change the water filter and plug in and switch on.
Run off around a gallon of water to prime the system. You should then get chilled water around 4 hours later and ice after 12 hours.
If there is still no ice you may find that the trace heater on the ice maker water tube is faulty and may need to be replaced
Apr 24, 2011 | Refrigerators
Noticed the ice maker quit working a day or two later noticed things thawing in freezer. a day or two later i noticed the refreigator wasnt cooling. cleaned everthing out and tried to freeze some ice cube...
you need to plug it back in and see if the compressor is running on unit... listen to it for about ten minutes or so do you here any clicking sounds coming fronm the rear if so this will be a a bad relay on compressor or something to do with the compressor... if you remove back cover you will see the compressor on the bottom of the unit and can pit your hand on it to fill if it is running..while back there make sure the fan in the bottom is running next to compressor... if all that looks good the unit is probley going to work like a champ for a few days you recall any frost on the back wall of freezer back wall... if so then you may have a defrost problem either the heater has failed,the evaporator fan located behind the inside back wall cover has failed. a thermostat has failed or the actually defrost control... let it run and see if the inside fan is running also.. you will have to remove back wall to check the heater using a volt meter and set it on ohms to check the heater for continuity... repost with anymore questions...
Jan 12, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
I have a brand new (2 days) Frigidaire Gallery series, 23CU side by side that is not making enough ice. We are getting water from the door, the ice maker will only drop about 3 times in 24 hours. the...
Good day,
Light usage in a cool kitchen will reduce ice production substantially.
When the ice maker harvests, it turns on a calrod unit located on it's bottom, that frees the cubes, and as well the heat from the calrod heats up an internal thermostat in the ice maker to a temperature in excess of 70 degrees.
Then it stays at rest, until the cycle thermostat reaches 12 to 14 degress and then performs another harvest cycle.
If the machine runs little, and the fan in the freezer is not circulating cold air, the harvest times will be extended.
Turning the freezer colder will always help.
There is a possibility, the thermostat in the ice maker is out of calibration, and the ice maker needs replaced. But try the settings first, and give it a week or two, before calling for service.
You have a lot iof time under warranty to resolve this issue.
Thank you for using FixYa.
Jan 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Does not make enough ice
Ice machines are rated in pounds per hour. They usually have an arm paddle switch that tells them when they are full or a weight switch that works the same way.
If possible, transfer the produced ice to another container when the machine is full and allow the unit to keep making ice.
This assumes the machine is working properly and that the cubes are solid. (frozen and not watery).
Dec 07, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
Not making ice
replace complete im and water filter , 100 % it will work :)
Jun 26, 2009 | Amana Refrigerators
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Oct 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
