Question about Dryers
Good evening I am an owner of a General Electric Gas Dryer Model PWSR483gb1WW it has never really dried my clothes properly (the temperature of the dryer when in function is 116 fahrenheit) the GE tech came to fix 4 times with no success. He replaced the 3 thermometers and the exit hose. Please help otherwise out to the alley it will go!!!
  • stefbig Jun 24, 2008
    The vent hose was short approx 3 feet long, the tech added another 8 feet and bent it at 3 different places to prevent the hot air to escape all at once. Now you are saying it should be short, should I remove the extra 8 feet of vent hose? This still does not fix my problem. Could the gas valve have something to do with my problem? The proper temperature should be at 135 degrees give or take a few degrees, but it has never obtained that heat.
    Help !!!
  • 21 Answers
How long is the dryer vent hose .It should be metal and as short as possible, best under 12 feet long. Is there any thing that can get in front of the vent outside that may block or hinder the exit of the hot moist air. Too long a vent pipe or a out side flaper that is not free moving will cause back pressure that will not dry your clothes without more that one drying cycle. Also lint can get stuck in the hose especially at any bends,can be a fire hazard.
Posted on Jun 24, 2008
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
My creda model tcr2 isnt drying my clothes
heatman101
Jul 30, 2011 | Dryers
Clothes not dry. Take about 3 hours to dry the medium load of regular clothes.
heatman101'
Jul 18, 2011 | LG Dryers
WON'T DRY CLOTHS..NO HOT AIR
heatman101;'';';
Jun 27, 2011 | GE Dryers
Samsung electric dryer model # DV328AEW not heating up to dry clothes
heatman101.,//';
Mar 09, 2011 | Samsung DV448AEE Electric Dryer
I dont know if this is the exact dryer I have or not but in general i have a couple of questions that need answered. 1) My dryer is no longer getting hot and drying my clothes 2) my timer never turns off...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | Kenmore 62802 Electric Dryer
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Nov 21, 2010 | Maytag Dryers
The air drying the clothes is cold, not hot. We have a Kenmore Elite Electric Dryer, Model 110 63952100
heatman101
Nov 04, 2010 | Kenmore Elite HE4 Electric Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    79 people viewed this question
    Top Dryers Experts
