Question about Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Kogi 15" flat screen monitor
I noticed a day ago that my monitor would just stay on and when I pushed the button to turn it off, it wouldn't click and would just stay on. I turned it off by unplugging it and the next day I plugged it into the surge proctector and nothing happened. Then I plugged it into the wall and the montior came on. I worked on it for 10 mintues and then my monitor screen just went off. Not sure what to do?
lukster
  • 217 Answers
SOURCE: on screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
Posted on Mar 17, 2007
SOURCE: Kogi L9ch 19 in flat monitor
(I posted the latest post.) Change the resolution. (Mine was 1024 by 768, so I changed it first to 800 by 600 and then back to 1024 by 768, and it's back to normal!)
Hope that helps.
Posted on Nov 05, 2007
florin_decad
  • 203 Answers
SOURCE: kogi monitor will not resolve screen
Startt the pc in SAFE MODE  and change thr resolution of the screen, the computer does not work on 1280 X1024, so AT THE BOOT TIME  PRES F8 chose save mode with windows, tan on the property of the display change the video resolution at 1280 X1024, and i think you don't have the video driver instaled not sure but u can chek that as well.chek run WINDOWS UPDATE if your diver is not in place. to chek driver take a look in computer management  DEVICE MANAGER.
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: kogi 17'' flat screen monitor
there are four(4) buttons on your monitor to the left of the on/off switch.
Press the first one to the left of the off switch, which will bring up a menu, so you can select
bright or volume, screen size, etc; Next, there are two (2) buttons to the left of the first left button
that you can push to adjust brightness, size, vertical, etc;
Posted on May 09, 2009
Messic
  • 94 Answers
SOURCE: I have a Kogi 15"
This is the cord you're looking for. It's the same as the power cord for PCs. Only difference is the right end of the cable as that depends on which country you are in. You should be able to grab one of these at your nearest PC shop.
Posted on Mar 04, 2011
I have a Kogi 15"
Mar 03, 2011 | Kogi Computers & Internet
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Picture is too tall - how do you make it shorter?
The buttons on the front of your monitor will have a set up. When you get into setup mode there will be a bunch of symbols. Use the other buttons to scroll around to the correct one. It will be the one with the arrows pointing to the top and bottom of the screen.
There should be either a + - button or something like that. Just push the one that makes the screen shorter to the desired height.
cheers and good luck
Nov 21, 2009 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Kogi L5QX monitor is not centered,
I tried the suggestion on one of your posts. Simultaneously, pushing in the two middle buttons on the front of the monitor. I figured it out from there. Thank you!
Oct 30, 2009 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Kogi L9CH monitor - black screen
return for a replacement, the screen is broken
Sep 13, 2009 | Kogi L9CH 19" Flat Panel LCD Monitor
Kogi 17'' flat screen monitor
Apr 03, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Goes Blank
ok ... i answered your last post as well. is there a reset button on it. the few lcd monitors i've worked on required pressing the far left hand button on the front to reset it.
Robert
Feb 09, 2008 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Kogi monitor ... it goes blank
Where can I buy the power cord for my KOGI L5QX?
Feb 09, 2008 | Kogi L7CH Monitor
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
On screen display on monitor locked and need to restore factory settings
Mar 07, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l5qx-ta ko 15" Flat Panel LCD Monitor Logo
57 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
William Miller
William Miller
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
