Question about Cameras
Canon Powershot SD550 flash not working
My camera was in a padded case and suffered an impact from about 4 ft high onto ground. All is fine with the camera except it will not function when set to use the flash. I have reset all functions and removed the battery and recharged it, but nothing seems to work. The "red eye reduction lamp" is functioning" but not the flash.
Do you think it is simply broken and cannot be fixed or is there something else I can do to restore flash function.
Thanks.
  • lmonnig Jun 23, 2008
    There is no pop up mechism to pry up.
    You just press the buttom to take picture and red eye lights up but no flash AND it does not even take the photo...so it basically seems like since the flash won't flash camera senses this and won't "take" photo.
  • jaclyn417 Apr 16, 2009
    i have the same exact camera and one day there is nothing wrong with it, the next i'm taking a picture of my best friend and i and it takes with this weird blueish tint, and the next day it won't take a picture with the flash at all. same deal with the orange light- it'll show but then no actual flash. afraid i'm going to have to buy a new camera... is that the case? :(
    Sergeant:
  • 284 Answers
Most likely it could be stuck
you can try prying up the flash a bit not to much.
otherwise its broken, the gears that runs it, could have a broken tooth.
so it wont pop up or go up.
Posted on Jun 23, 2008
  • Arcadian Duran
    Arcadian Duran Jun 23, 2008
    oooh okay the the element inside the flash is broken the glass part prolly lost the vacuum inside.
    its would prolly cost to much to repair, than what the camera is worth.
Flash is not working
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Dec 31, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Flash not working
Needs to go to repair shop, will be either the Fuse on the front PCB to the flash, or the flash circuit. You could try a rest first, just in case - ress Menu, go accross to the spanner, and down to Reset
Jun 02, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon sd550 no flash cant take pics. at night
Let me tell you the possiable causes of this issue you having with your camera and then you can decern the best course of action.
the flash has a capacitor inside the filles up with power from the battery then once charged dilvers a sustained voltage to the bulb to create the flash.
Now if this componet has failed or is intermittant then this would happend.
Keep in mind that a battery that is towards the end of its prime will do this to so do not just go for repair all of the sudden try a new battery. If the new battery does not work then you know you got the issue I am talking about thus you going ot need a camera shop to change out that peice.
thanks for your attention and prompt ratings and feedback today.
Apr 29, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Have Canon Powershot SD550 but no software
Here is a clickable and direct link to the Canon web site with the software you need for your Canon Powershot SD550 Digital Elph.
Hope this helps you!
- CBR2009
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=12466#DownloadDetailAct
Aug 18, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon 10D works fine after impact but overexposes now.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI,YOU SAID YOUR CAMERA WAS FALLEN ON THE FACE WITH LENS THEN STARTS OVR EXPOSING PICTURES THEN FIRST CHECK YOUR LENS'S APERTURE IS WORKING FINE OR NOT.ATTACH ANOTHER LENS TO YOUR CAMERA & THEN CHECK THE EXPOSURE THEN IT WILL BE CLEAR WHETHER YOUR CAMERA IS DEFECTIVE OR LENS IS DAMAGED INTERNALLY.REPLY ME ABOUT IT.THANK YOU & ALL THE BEST
Aug 02, 2009 | Canon PowerShot SD1000 Digital Camera
Flash not working
You must get a reapir shop to replace the flash unit = about US$100 or so.
Jul 15, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Picture will not take when flash is on
How old is the battery? The symptoms you're describing sound like a worn down battery. If it's the original battery that came with the camera, it may be time to consider a new battery. One way to check the battery's health is to apply a voltmeter to it, and compare its voltage with that printed on its casing. Replacement generic NB-3L batteries are going for about $7 on Amazon or ebay.
Mar 07, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Cameras Logo
262 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
