Question about Coleman Heating & Cooling
I broke my plugin cord for my coleman portable hot/cold fridge, how do I get a new one?
  • 40 Answers
Unplug it. Remove back panel. Study how your wires are mounted. Make a diagram if you need to. Take it with you to Home Depot and whola...You just saved a couple hundred bucks
Posted on Jun 23, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
What oil wieght oil does the powermate 5000 use
a 10-30 multi weight oil should work fine, in the winter, if it gets cold there, a 5-30, if it gets super hot in summer, a 10-40
Mar 10, 2013 | Coleman Powermate Portable Generator...
How do you get the pull cord back houesing off. do i have to take the carbarater off first. The rivets broke off that hold the pull cord houseing to the flyweel housing and i have to use nuts and bults...
Easy fix for your rewind problem. We just drill out the old rivets and pop in new rivets from the outside. Very easy very quick. Dont need to take anything apart and lose the factory torque /locktite on bolts. We do not use screws because there is so very little space between the flywheel and starter cover if screws come loose they may cause damage. If you do not have a rivet gun, check with local pawn shops, thrift stores etc. and get one for a few dollars. Good luck with your repair.
Apr 23, 2011 | Coleman Powermate Premium Plus 6250W...
Have a 5000 watt portable generator when running AC on a hot day it will pop breaker after about 30 minutes
Extension cord will cause it to trip. Make sure it's big enough and as short as can be. worn breaker will trip easier.
May 30, 2010 | Coleman Powermate Powermate 5000W...
Keeps blowing fuses will not stay running
What are you plugging it into? It needs a 20 amp breaker, and no extension cord, and it has to be warm. In cold weather they are sluggish, a cord will drop the amps down quite a bit, if it doesn't have the at least 16 amps on start up , it will pop a breaker. So check this out. hope it helps.
May 03, 2010 | Coleman CP0302013 20 - Gallon Portable...
My pull cord is broke. How do I thread a new one through?
unscrew the cover where the cord goes in there is a gap in the wheel where the cord is on. take old one out and make newone in. wind up the spring and test. replace cover.
Feb 10, 2010 | Coleman Powermate Premium Plus 6250W...
Heater won't blow hot in my coleman Seapine
did you try the limit reset button? It is red and may be close to the blower.If your pilot is on and burners don't come on this may be it
Jan 15, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
WE HAVE A COLEMAN 5640 PORTABLE FRIDGE. WE HAVE ONLY USED IT TWICE, AND JUST GOT IT OUT FOR A WEEKEND TRIP(TO PUT INSULIN IN)BUT IT ONLY HEATS UP, NOT COOL. ANY IDEAS? wE HAVE BOTH THE CAR ADAPTER AND...
I bought one but it was missing the cord, so I hooked it to the benchtop supply. I found out if you place positive to the red terminal/grey wires under the outside cover and negative to the blue/black wires it cools. With a DPDT switch and a couple of LEDs you could wire it so you dont need that special coleman cord, any lighter cord will work provided it can handle about 6 amps, I recommend 12 to 14 gauge wire and a 6 amp fuse.
Jul 18, 2008 | Coleman Refrigerators
Heating & Cooling Logo
22 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
