Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
G E Monogram side by side refregerator ZISB420DMC
Water dispenser just stopped working. Ice dispenser still working. Replace filter still no water.
Thanks
    Problem Solver:
  • 7 Answers
I'm just a home owner, not an expert. Could be a frozen line. I think GE has had problems with this. I think they've retro-fitted their doors with better insulation that prevents the lines from freezing.
Posted on Sep 05, 2010
My in door water and ice dispenser will not shut off
Water valve may be stuck open or switch is defective constantly calling for water.
Mar 26, 2014 | Refrigerators
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
[LG Refregerator] Model LFX25961AL water does not dispense and ice is not being made
Make sure the wire guide that pulls up when ice is at full capacity is not accidentally pulled up. (this is above the ice bin in the freezer). Pull back down and should make ice.
Dec 17, 2013 | Refrigerators
Need to replace my ZISB42DCA should I go with latest Monogram or a comparable Profile or switch to Kitchenaide. We have had a lot of problems with this one but it came with the house.
I have a 42" GE monogram refrig: ZISB420DMC. Water dispenser has had all kinds of problems and I've already had it fixed once. Same for ice dispenser. I just get ice directly out of the bin rather than have it dispense ice. This refrig also doesn't seem to have very much storage space. I can't even put a large pot in the refrig because of that silly light in the back of the refrigerator. I don't like GE refrigerators anymore. I've seen friends and family buy the Samsung refrigerators. They are really nice and I would get a Samsung. Here in Hawaii, Lowes seemed to have the best prices on the Samsung refrigerators.
Aug 17, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Water dispenser has stopped working. Ice maker still works and I've changed the water filter. Still nothing
There are two solenoid valves in the rear of the refrigerator. One that controls water for ice and one that controls water for door dispenser. If the water is not coming through when the button is pushed then have the proper solenoid valve replaced and enjoy. Hope this helps. good luck.
Jul 18, 2009 | GE Monogram ZISS480DRSS Stainless Steel
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Apr 14, 2008 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
648 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
