Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ahhhhhhhh i have a whirlpool freezer i dont know the actual make by it is a black side by side, my freezer is icing over and when i open the freezer it snows.lol. seriously how do i fix the freezing problem and how do i defrost the freezer with out it affecting having to turn the fridge off.thank you
    Genius:
  • 1,073 Answers
Look inside the despenser in the door and make sure that the flapper that when you get ice through the door is sealing off the shute.
if it is not sealing it off there is a kit for the problem
as far as defrosting the fridge you can use a hair drier and remove the frost, you will need some towells to get up the water
Posted on Jun 24, 2008
Freezer is not cold enough. appears tobe cooling just not enough. turned dial to colder. things are still thawing. Is it possible freon is low? we have had this refrigerator for about 5 years. Also it says...
First thing that can be checked is for dirt and dust accumulated on the underside grill or behind the fridge. Clean this up thoroughly and check if things get better.
In normal cases freon shouldn't escape because its is a sealed system unless there is leaks, this could actually be the case.
Get it checked.
Or your compressor may be dying out. Is there any weird noises?
Mar 03, 2011 | Whirlpool Refrigerators
The freezer keeps defrosting and re-freezing again
First you need to remove plastic cover inside freezer compartment back wall at the bottom and check for build up of frost in the freezing unit if so your defrost system is faulty
Mar 18, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Whirlpool Gold Side By Side Ice Dispenser Problems
Instead of what you think the sound is, try and see what is happening when you actuate the ice lever. open freezer door, depress the door light switch, or tape it closed. now actuate the ice dispenser lever, does the flapping door open, that which opens to allow ice from bucket into your glass? Now look at the bucket itself, do you see the gears rotating? remove the bucket from the door, and repeat, do you see the auger shaft rotating?
Either of these are a complex repair, one I would not recommend DIYers to try on their own, for they require taking the door apart, and if not done right, your door may not close properly. Normally I have no problem advising a repair, but there are some i dont, this icemaker system, and compressors.
Visit www.FixMyFridge.net for refrigerator service or to ask general refrigerator questions.
Dec 11, 2009 | Whirlpool GS6NVEXSL Side by Side...
Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea breezehvac@yahoo.com
visit my site below
http://servicepartstec.blogspot.com/
Mar 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator ice maker not making ice
actually it should be blinking when door opened, try closint the little flap on left side of freezer liner, does hte light then become solid??? if so the electronic control is working correctly.. open the flap acessing to ice maker itself is there any ice in the machine now?? perhaps an ice cubes is jammed and not allowing hte icemaker to advance.. ck the little black nozzle(fill tube) crush it with your fingers is it full of ice???if so your fill tube is frozen and needs to be thawed. this is a pretty hard ice maker to trouble shoot. lastly theres ascrew under the rt corner if ice machine 1/4 nut driver. remove htat screw it releases acover for wires. the ice maker will pull out (youl need to push up a little tab along the left siderail inwhich the ice aker sits , after removed pry off the white cover if ice maker and look at the center gear. sometomes the tabs holding that gear on are broken in which case hte ice maker wont work and needs replacing(you cant sevice the main gear replace the entie assy. let me know what you find( iknow it sounds like a lot but youll be alright!!!!!
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
