Question about Hitachi 55HDS69 55 in. Plasma Television
Set tv i accidently bumped the remote i need to know how to set it back , usely i would put on channel 3 i have 2 remotes 1 for box and the other fromhitachi
    Problem Solver:
  • 53 Answers
Hello Dchampgus
Which remote are you having the issue with and are you having a problem with programming your box remote or is it the Tv remote
Posted on Aug 09, 2008
  • mark mayers Oct 03, 2013
    having same problem.hit tv remote by accident (menu button?) and now trying to get picture back?
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Tv does not respond to remote commands
You need to isolate the problem.
1) Unplug the TV for a few seconds and then plug it back in.
2) Operate the TV with the buttons on the TV. (Channels etc) I presumed you have scanned in the channels.
If no problem found then do this for the remote.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Now try the remote to see if it works. If it fails you will need a new remote.
Mar 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Magnavox converter box and tv preset channel
Have her take the remote and hit 03. Alot of people think hitting the 3 only will work. Not the case have to hit 0 then 3.
Jan 11, 2009 | Philips PM-DVR8 Remote Control
Olevia tv erased all channels accidently
BEVERLYQC::
How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Oct 22, 2008 | Olevia LT42HVi 42 in. LCD Television
No channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Hitachi 55HDS69 55 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
