Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Get parts from maytag and not covering things
I BOUGHT A THREE DOOR REFIGERATOR NOT EVEN A YEAR BOTH BOARD WENT OUT. KNOW IT IS PLAY HELL TO GET A PART SO IT WILL DEFROST. IT HAS BEEN TWO AND HALF MONTHS AGO I CALLED SOME ONE TO FIX IT AND THEY KEEP SAYING THE PART IS ON BACK ORDER FROM MAYTAG. I TALKED TO THE REPAIR PLACE TODAY AND KNOW THEY ARE TOLD MAYTAG CAN'T SEND THE PART OUT TO THEM. THAT THEY NEED TO ORDER IT SOME WERE ELSE. WHEN THEY CALLED THIS OTHER PLACE THEY DON'T DO THAT EITHER. SOMEONE BETTER FIX IT OR TV MEDIA AND INTERNET WITH HEAR WHAT I HAVE TO SAY ABOUT MAYTAG.
  • byeakey Jun 24, 2008
    Yes, I did phone them and they told me about a month ago they would call me back. I have tried to call them again and that is the same answer I get. They will look into it and call back. have not heard from them yet.
    Problem Solver:
  • 9 Answers
Did you phone Maytag direct?
Posted on Jun 23, 2008
I have a Maytag French door refrigerator model MFI2568AEW that the control panel is flashing and ice door is flapping. Called both 800 numbers listed they said no recall. someone help on how to fix.
Your high voltage board is out part number 12920710 You will find this board on the back of the refrigerator under a square metal cover, once you remove the cover you will find an additional cover made of clear plastic. Make sure the refrigerator is unplugged before you go any further. Once you install your new board you must program the board with the instructions in the box. Follow them careful because it is easy to mess up. Your refrigerator will not run with out being programed. Also, take the old board back to where you bought it and ask for the 60.00 dollar core to be refunded to you. Maytag has a bulletin out R8178660 April 2007. If you need additional help let me know
Feb 01, 2016 | Maytag Refrigerators
Maytag refrigerator bottom pull-out drawer has frost inside. Kept running all night long. One year ago we had to replace the ''board'' and now it's happened again. (Unit only three years old then. Dealer...
frost is a sign that warm air is coming in from somewhere,the most common issue w/ bottom freezers is the door can appear to be shut,when its actually not.always shut door from the middle of the door,not sides. if a bottom freezer is preffered-i suggest a swinging door vs. the sliding drawer....
Mar 10, 2010 | Refrigerators
My washer will not come on.
Check the door switch. I remember something about this machine from 7 years ago when I went to school on it. If it is the door switch, it also put pin #12 (Not sure about #) out on the board. If you change the board out without changing the switch. It will burn the board out again. So if you see a burnt place on the PC board, call factory and ask them before you change board. Sorry I couldnt help more but I do remember some thing about this and I didnt want to see you replace the board with a new one and it burn out as soon as you hook it up. They cost to much to be buying three or four of them.
Sep 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Jul 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag refigerator dripping water internally from freezer on top
you have a drip pan under the frig dump it.. yes its defrosting
Mar 24, 2009 | Maytag PTB1553G Top Freezer Refrigerator
Maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Oct 23, 2008 | Washing Machines
Maytag Ice2O
I had the same problem 4/28/08 - Called Maytag they're sending the part and repairman free.
IN THE MEAN TIME.......Maytag suggested to me to: take a phillips head screw driver and remove the hinge cover from the top of the left door. You'll find a white connector with four wires coming from each side. Disconnect the connector in the middle and the flap will stop (and so will the lights).
Feb 20, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
May 21, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
75 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
