Printer Drive Problem
When we went to connect our printer to the new computer it was telling us that the Windows Vista did not recognize the print drivers for the Brother's MFC Printer. We followed along intructions to install them. Then installed the printer software. The printer is now working. But when we logged into the computer today we got this error message: "Failed to Start the Control Center. Please reinstall the MFL Pro Suite (CC3-001-00001907).
Please advise
  • 1 more comment
  • Barbara M Jun 24, 2008
    But the MFL ProSuite is the CD for downloading the printer software. Our printer model is MFC665CW.
    But since the printer is working, maybe one of the other functions didn't download properly?? Which I am not too concerned about. Is there a way to stop this error from popping up everytime we sign on??
  • alboncom Jan 06, 2009
    fff
  • Simon Vann
    Simon Vann May 11, 2010
    What model MFC do you have?
    Novelist:
  • 121 Answers
Since the printer is working the drivers are installed correctly. The drivers help the computer recognize and operate your printer. The error that you are recieving is from the program called MFL Pro Suite. If you still have the CD you can reinstall the software and this error should go away. If you found solution this helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
I get a message "
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Aug 08, 2011 | Lexmark Z816 InkJet Printer
Install drivers for hp 3050 and it still won't
If your installing your printer onto different computers and they aren't working on any computers then that tells me the printer is not working at all. Usually a problem with the main board.
Apr 22, 2010 | HP LaserJet 3050 All-In-One Printer
Please uninstall all drivers and software related to printer. Detach printer from computer connection.
Install drivers and software without the printer connected.
Restart computer and connect printer.
Thanks and Good Luck! =)
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
I have a Lexmark 5490 connected to a D-Link DPR-1260. The D-Link configuration utility installs the printer on my Vista Home Premium laptop as the default printer and recognizes that the printer is...
Check your windows firewall or your antivirus.
Disconnect that for a while and delete all pending documents (queue).
Send a new doc to print and see what happen.
Usually those program are blocking the communication between printer and computer.
If this is your case, set a rule on your antivirus program.
Have a great day!
Pablo :-)
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Vista print drive for the konica minolta 2400w
If you are using the USB connection, got Control Panel, Device Manager and delete/uninstall the last listed USB Hub - and wait a moment for the system to re-recognize what's connected. If there is a page in the cache, it will automatically start to print.
Sep 12, 2008 | Konica Minolta magicolor 2400 Laser...
I have a Cannon i9900 and I love it! Bought a new computer running Vista x64. Went to the web and downloaded the Vista x64 drivers for the printer and the Easy Print which I also like very much. The new...
If you can print, than it is possible the computer has recognized plug-play (PnP) printer. The downloaded program may not be the one for your specific printer.
May 17, 2008 | Cannon Office Equipment & Supplies
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
How do I get my Epson Stylus Rhoto R220 to work with windows vista
I have an Epson Stylus Rhoto R220 inkjet printer for 10 months and i would like to know if its going to work with Vista Windows PC or it won't recognize my printer. How do I upgrade it or get it compatible ?Thaks
Feb 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Printer not recognized
Paste this address into your browser it will take you to the driver for vista. http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:385:0:0&searchLang=en&os_group=Windows%20Vista
Aug 11, 2007 | Lexmark X6150 All-In-One InkJet Printer
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
