Question about SanDisk Sansa m240 MP3 Player
Won't Turn On
I had my Sansa e280 plugged into my computer overnight, but I noticed after I rebooted that I could not get the player to turn back on no matter what, whether plugged in to the computer, the wall, or running on battery (which I know is fully charged). The player doesn't seem to have a reset button, and I don't know how to get it to turn on again. my mp3 does nt turn on an the batteryits ok
  • 8,596 Answers
Make sure hold/lock not enagged
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jun 27, 2008
Sansa e280 was charging on the computer and computer died, now mp3 player won't turn on anymore, even when charging
Hey its Sunil here....
Just open the back panel of the Sansa... Take out the battery & replace it and switch it on...
Feb 18, 2010 | SanDisk Sansa E280 MP3 Player
Sansa not charging
Try plugging in the sansa before you turn on your computer. Push the on button of the computer, then immedietly push the on button of the sansa.
Jun 11, 2009 | SanDisk Sansa E280 MP3 Player
My Sansa e280 won't turn on
Hold down the menu bottom for about 20-30 secs. Should power back on.
Mar 17, 2009 | SanDisk Sansa E280 MP3 Player
My sansa E280 will not turn on
I have more advice on my Tips & Tricks for fixing Sansa players, but here is a likely candidate:
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e280
getting warm is normal I've never seen one get HOT, you can pull out the battery from these players very easey by removing 4 screws from the back of the player take it out for a minute and this should reset the player, if not you may need a new battery these are on Amazon for short money.
Oct 16, 2008 | SanDisk Sansa E280 MP3 Player
hi sir..
please install the firmware. i will solve it. follow thw link it will be useful www.woot.com/files/sansae200manual.pdf . rate it sir..
Sep 03, 2008 | SanDisk Sansa E280 MP3 Player
Won't Turn On
Make sure the hold/lock is not engaged.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 23, 2008 | SanDisk Sansa E280 MP3 Player
Won't turn on.
Fixed my "dead" Sansa by opening the back, removing the battery then putting it back in. This appears to have rebooted the system and now it's working fine. No files were lost.
(I did try holding down the on/off button prior to this but got no response at all.)
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
Sansa e280 malfunction
i have solved my problem !!
if it says connected and when you plug it and out and it is still not working you just plug then unplug (might take some time)
Nov 18, 2007 | Audio Players & Recorders
Need help quick with sansa e280
try switching your usb mode, do that by going into settings, this might help but im not sure
May 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
