Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Proheat Clearview 1669
I need to get to the heater in the handle since everything has been checked and I still do not get any fluids to come out. They do come out through the accessory hose. I read that since everything has been checked and cleaned (filters, etc.) that I need to clean debris from heater but I can't seem to get to the heater. I removed all the screws in the handled but still was unable to see heater. can you help?
Thanks so much!!!
Linda The problem with the machine is that I get no water or solution out of the bottom nozzles. The hand-held portion works fine, but no spray from the bottom. I've checked the hose lines, made sure that the nozzles were clear of debris, and still nothing. Everything else works fine and it seems like everything is seated properly (if I dry out the connections for the solution tank and the water tank and seat them, they're wet when I pull them up and water is in the line). Any suggestions?
Thanks!
Chris
    President:
  • 1,673 Answers
Take out the 2 long screws with the nuts on them, then furher down just beneath the hose wrap asm, there are 2 more screws to remove. Put the top part of the handle off, lay the handle down, on the front, at the top and in the center is a tab, push it in and pull the top half of the handle away from the bottom half. Then you will see the heater, don't mix up the hoses after you are done.
Posted on Jun 24, 2008
I need the part that holds the hose in place when not in use. it is a clamp like plastic at the top by the handle.
Check out the vacpartswarehouse dot com and type in your model number. They have decent schematics that may help you find your plastic clamp.
www.vacpartswarehouse.com/Bissell-ProHeat-ClearView-Deep-Cleaners-s/545
Oct 18, 2013 | Bissell 1699 ProHeat Clear View Upright...
I can't get the lower handle cover off the Bissell
Did you ever get the lower handle unit unsnapped from your Bissell Proheat? I can't get mine off so if you have any suggestions, please let me know.
Jul 07, 2011 | Bissell 7901-R Clearview Proheat Plus...
Need manual for bissell proheat clearview force rug cleaner
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Aug 21, 2010 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Proheat Clearview is not spraying water nor taking
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
wrthrw
Apr 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
How to replace belt on a bissell proheat clearview plus carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Jan 27, 2010 | Bissell 7901-R Clearview Proheat Plus...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do i put new belt on
Here is a link to the manual and to the belts you need. hope it helps!
Bissell ProHeat Manual and Belts
Nov 21, 2009 | Bissell 7901-R Clearview Proheat Plus...
Bissell Proheat 7901-R not doing anything--ready to scream!
heatman101
ewtywe
Mar 12, 2009 | Bissell 7901-R Clearview Proheat Plus...
Take off the 2 long screws and remove the top part of the handle. Then from the back, just undr the hose and cord wrap asm, there are 2 screws set deep in the holes to remove. Don't remove the cord and hose wrap. Then lay the handle back, at the top, in the center, there is a catch to push in, then the top half will come off and you can get to the heater. Remove the hoses, one of the hose ports maybe clogged, clean them out, sometimes stuff in them gets pretty hard and hard to clean out.
After you may want to run a mix of vinegar and water thru the system to clean it all out.(not on your carpet tho)
Jun 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
My bissell powersteamer clearview will not **** up water
Check the heater inside of the handle, it may be clogged and not allowing water to flow. The hose doesn't use the heater and that would be why it flows out the hose.
Apr 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
87 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
