Question about Dishwashers
New World DW60 dishwasher not working originally had E4 fault Power comes into the PCB the switches and led's light up but nothing happens. After about 5 mins there is a short beep. Does not show any error codes, New World sent a replacement PCB which made no difference except now have no error code. Circ pump, inlet valve, heater, drain pump checked independantly all worked.
  • Anonymous Jul 10, 2008
    the wash light keeps on bleeping and flashing
  • 868 Answers
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
Dishwasher bottom part works top part all lights are on and wont work
I'm assuming its a fisher and paykel, you will certainly need more info. Do you have an led display or 3 buttons and lights. Any fault codes, flashing beeping when buttons are pressed etc. If everything is normal no unusual beeps lights etc but nothing AT ALL happens when you press start it is the door 'switch' which is actually a light that is reflected through a plastic prism and back to itself ( originates from the board) check the prism top right drawer frame. Just compare to working drawer. If not more info required.
Jul 07, 2013 | KitchenAid Dishwashers
I have an electrolux dishwasher model #=EIDW6105gS0. All lights are flashing on the console and will not let me select any of the modes...will not run at all. Is there any way to reset? I have tried...
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Apr 06, 2011 | Electrolux Frigidaire Professional Series...
New World Integrated Dishwasher DW60 E4 flashing and beeping. Managed to get it going for a while with a d/w cleaner, it filled, water heated but then E4 error kept flashing and it stopped, had to...
Sounds like the drain pump has jammed - probably a bit of broken glass or a fruit pip, etc. isolate electricity supply, lie the machine on its back, after removing as much water as possible with a sponge etc, remove the base plate if fitted and the small drain pump should be removable, either secured with screws or just a simple 'twist' bayonet cap fixing. Check for blockages / foreign bodies in pump.
If not pump, ie you can hear it running on drain cycle, check drain hoses and plumbing for blockages. Remember there are usually two pumps, the bigger one is the wash pump. Some machines use 1 pump only, and reverse the direction of rotation for wash / drain. A foreign body in these pumps often rips all the rotor vanes of and you will need a new pump.
Feb 02, 2018 | Dishwashers
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
We have a kenwood kdw12st3a dishwasher - ever since we have had it, it has been nothing but trouble. It constantly flashes e4 so we have tipped it and drained the water out of the bottom (as advised) and...
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Jun 30, 2008 | Dishwashers
New Lamp turning off after 5 seconds
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Zanussi dishwasher DE6744 power indicator light on but when program buttons pressed nothing happens
I had the same problem, in my dishwasher ZDI6895sx the solution to my problem was in the connection between the main PCB and the display/ control pcb on which the buttons/ led's etc are mounted.
On my machine there are about 8 wires in a ribbon type connector which connect the two pcb's, the connection to the main PCB is soldered and on the smaller PCB is a push on fitting, the connections on this pcb are prone to oxidation, there could also be stress on the connector from all of the button pushing, check the connecting wires for continuity with a multimeter if possible but otherwise just remove the connector from the samller pcb clean well(reflow with solder if required) and reseat the connector in its original configuration.
As always only perform this repair if you feel confident and have turned all power to the machine off prior to dismantling.
Let me know how you get on.
Mar 29, 2008 | Dishwashers
New world DW60-flashing lights
This dishwasher uses the program lights a s a fault code. Usually it is due to food jamming the impeller. If you are competent you can get at it from underneath. Mine was under warranty when this happened and the engineer was heard to say, 'this is a dishwasher not a waste disposal'. The engineer cleared it with a wire coat hanger down the drian hole inside the machine. Not happened since we really scape off plates.
Oct 20, 2007 | Stoves 27 in. DW60 Built-in Dishwasher
Dishwashers Logo
835 people viewed this question
Top Dishwashers Experts
