Question about Soleus Heating & Cooling
I have a portable dehumidifier Model # cfm40E. It is leaking due to iced up coils
  • 40 Answers
Needs cleaning.
Posted on Jun 23, 2008
Unit forms ice on back coil. Please advise
The freon in the unit is low. You probably have a leak.
Jul 13, 2014 | Friedrich D40 Dehumidifier
There is ice on the filter and the filter will not come out. Tried turning off so it would melt, but filter still stuck. It is summer so why is ice forming?
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I had mine ice up once or twice particularly on very high humidity days > 90%. Once it thawed out. I was able to remove the filter. Most likely it is due to dust getting on coils & condenser Or actually has a Freon leak. to resolve the dirty coils you can easily dissemble (that is remove front & rear cover) it to give coils and condenser a good thorough cleaning. It the coils and condenser are not at all dirty, then is not the cause of the icing. The units are typically not serviceable - i.e. a disposable small appliance.
Jun 02, 2014 | Whirlpool 75-Pint Dehumidifier
Condensation on frigidaire dehumidifier turn to ice
Good Morning Friend,
I understand that the condensation is turning to ice on your Frigidaire dehumidifier, model# LAD704TDL. This can be a possible cause of your dehumidifier being turned on recently. This is normal, due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another possibility is the room temperature is too low. All dehumidifiers will operate satisfactorily at temperatures greater than 41 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
May 27, 2014 | Frigidaire Dehumidifier LAD704TDL
Why does Frigidaire dehumidifier LAD704DUL has ice on the coils?
Hello Friend, thank you for your question!
I see that you have frost accumulating on the coils of your Frigidaire dehumidifier, LAD704DUL. Typically frost appears on coils either because your dehumidifier has been turned on recently or the room temperature is too low. Sometimes this is normal due to refrigerant rushing through the coils and usually it disappears within 60 minutes. However, if your dehumidifier is not removing moisture, then at this point your dehumidifier may possibly been experiencing a sealed system issue. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Hope this helps! - Z
May 15, 2014 | Frigidaire Dehumidifiers
Icing on Coil
Unit has a leak...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
Jul 08, 2010 | LG Goldstar 30-Pint Dehumidifier
Dehumidifier ice buildup on coils drain is clear.after running 15
Your dehumidifier is very slowly leaking refrigerant...
This causes the coils to get too cold.....
The chances of finding this leak are slim to none...
Also would cost more then the machine is worth...
Junk this one and buy a new one...
Wish I could give you better news...
Apr 12, 2010 | Maytag M7DH65B2A Dehumidifier
Coil Icing at times need operators manual model 53701
either your coils are dirty or the unit could be low on refrigerant,or you may have an air leak inside the unit
Oct 28, 2009 | Kenmore 53701 Dehumidifier
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
The coils on my dehumidifier are frosting over.
Are the coils clean? If it has a filter is it clean? If yes to both, it has lost (leaked) refrigerant and it's time to buy a new dehumidifier. If the leak can be found it probably wouldn't be repairable and would cost more to fix than it's worth.
May 05, 2009 | GE Dehumidifiers
Soleus CFM40E
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Heating & Cooling Logo
83 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
