Hey piticanella,
What is most likely the cause of this is a faulty sensor, and you should have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out for service. I will say that unless the camera is covered under the manufacturers warranty digital camera repairs often exceed the value of the camera. I hope this helps!
Horizontal may not be due to the CCD sensor. It can be due to the lens itself. I swap lens from a non-working camera to replace the one with horizontal lines. I found out that I was able to get the camera to work to take great pictures.
The camera hasn't been used in a while, so I thought I take it out for some use. When I turn it on,...
(More)
The camera hasn't been used in a while, so I thought I take it out for some use. When I turn it on, the screen is white and there is a crack off to the side, on the inside of the camera. So who do I go to in order to fix it, or is it simply a lost cause?
hi i have hp photosmart m537 my stepmom bought me 3 years ago from walmart nice little camera only...
(More)
hi i have hp photosmart m537 my stepmom bought me 3 years ago from walmart nice little camera only problem is the battery door the clips are broken off inside it the battery door doesn't close all the way with the batteries in it
horizontal white lines all through the photo, even though all appears normal on the screen before...
(More)
horizontal white lines all through the photo, even though all appears normal on the screen before capturing the shot. Time for a new cam, or can this be fixed?
