Question about Frigidaire Dryers
I recently converted my Frigidaire Dryer "Model GLER341A52" from a 3-prong to a 4-prong outlet. I matched the color coding, "orange to orange", "white to white", "black to black" and the green ground to the existing green ground. Sounded simple enough; however, regardless of the setting I choose, the heating element seems to run at high intensity and actually makes the top exterior extremely hot to the touch (enough to burn a person). Is there a workaround to lessen the intensity?
    Genius:
  • 1,122 Answers
Heres a rule of thum,the white wire always goes to the middle terminal then the two legs one on each side and ground to the g other green or to the cabinet,if that's not the problem it sounds like your hi temp thermostat is not cycling,if you have a volt meter with clap you can put it on amps and clip to one side of power cord to check,you should get from 3-5 amps and then when it cycles off about 1 amp,if you don't you have to replace the high temp thermostat,let me know,thanks-mike
Posted on Jun 23, 2008
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I am trying to convert the 3 prong cord to a 4 prong cord and don't know where to put the grounding terminal from before...it was on the dryer internally.   I got everything hooked up correctly (i...
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral and ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 09, 2010 | Whirlpool WED5500S Electric Dryer
I have a 3 prong to change to a 4 prong cord on my dryer
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Feb 06, 2010 | Dryers
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Dryers Logo
43 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
