please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The
Battery Recharger Fix-It Guide)
or replace a battery that won't hold a charge. Make sure the AC adapter
is connected properly. Clean any dirty contacts on the battery,
charger, and AC adapter with a cotton swab dipped in denatured alcohol.
Remove corrosion with a clean pencil eraser, then wipe the area with an
artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery.
Also, turn the video camera power off, then turn it back on and eject
the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge
the battery, then recharge it. If the problem persists, replace the
battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
