Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
How to fax when ink cartridge is empty
The 5500 black ink cartridge needs to be replaced. How to get the printer to perform other opeartions (e.g., faxing) while waiting for the cartridge to be replaced?
Thanks!
I talked to Kodak and you can't. You have to have all ink cartridges filled and ready in order to perform any operation! I know, it sucks!
Posted on Jun 27, 2008
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Printing with my Kodak easyshare 5300
it is necessary to install the colour cartridge.to use with black
Aug 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
No colour cartridge
you need to replace the color cartridge
Jun 05, 2010 | Kodak 5500 ALL-IN-ONE PRINTER
Do i need an ink cartridge for the fax machine to work and setup
Some brands of fax machines and all-in-one printer/scanner/fax/copiers need the ink cartridge to be present and have some ink in it to perform functions which don't actually require ink.
My dad bought a Brother all-in-one, and he is unable to scan or send faxes unless he replaces an empty ink cartridge first. If you have a Brother fax machine, I'd suggest returning it and buying a different brand. They waste ink on unnecessary cleaning procedures and force you to buy more for stuff that doesn't need ink.
Mar 03, 2010 | Samsung SF-3200 Fax
Can't send fax because of message: Ink Empty Black-Replace Ink
No, the machine needs to have all cartridges installed to perform all actions, including fax and scanner functions.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Can you turn off the ink level functions on a Kodak 5500 printer?
According to a recent report by PC World, you must change it and there is no way arond it. It still turns out to cost less.
Jan 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I'm trying to fax, it says color cartridge replace
marcarrico,
Even though you do not print in colour, your printer will still slowly but surely **** out the colour ink in your printer/fax machine. The unit does a thing called purging. this is a necessary part of the printer maintaining the print head in a printable condition. Everytime it does this it will **** a small amount of ink through the head, Including your colour inks. Over time the inks will empty even if you don't use the ink. All inkjet printers do this and there is not a thing you can do about it. If you want to use the printer, you will have no choice but to replace the colour cartridges.
As a suggestion, if you only ever use black then you would be far better off with a small laser fax. they start from about $350au and they will give you a better print in text and the cartridges will last about 10 times as long as the ink jet.
Gremlin11
Dec 11, 2008 | Kodak 5500 ALL-IN-ONE PRINTER
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
When printing, the black ink barely works, acts like it is empty.
Basically you have done most of the procedure for this issue, try resetting the ink then try again, for same issue call support for printhead replacement 1 800 421 6699
Nov 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother MFC 420 CN
the brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother.
Feb 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
