Question about LG Refrigerators
The water and ice dispenser not working - LG Refrigerators
    Problem Solver:
  • 9 Answers
Check and make sure the water supply to the fridge is not turned off at the main supply (perhaps under your sink)_
Posted on Jun 23, 2008
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
129 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
