Question about AMD SEMPRON 3300+ SOCKET 462 OEM W/O COOLING FAN Important Installation | (SDA3300DKV4E)
Cooling fan? I am trying to remove my radiater fan moter and dont know where to begin?
  • Anonymous Aug 08, 2008
    i need driver my processor no dot run perfect programs and games why is problem helper me please
  • 99 Answers
If I understood your question, you're trying to remove your Heat Sink/ Fan.
First you need to unplug the fan's power source from the motherboard.
Then there should be a lug that clips your HS/F to the motherboard. The lug runs through the HS/F, and one clip should be slightly larger than the other. Gently push down on the clip that is slightly larger until you get it free and then unclip it. The other side of the lug should come right now. After you make sure that all the clips have been removed, you can pull off the HS/F
Pretty much follow this guide in reverse:
www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/23986.pdf
Posted on Jul 26, 2008
Car running hot when idle
The most common reason for running hot at idle is the radiator fan is not running or pulling enough air thru the radiator. If you have a fan for the engine and one for the ac, the engine fan may not be working.
The radiator fan should come on when the coolant reaches 220 degrees. The computer sends a signal to the fan relay.
May 15, 2013 | 2004 Buick Century
My radiator cooling fans are ticking and smells like its rubbing and burning. can i disconnect one fan
probley wouldint be a good ideal the coolness of your eng is the life of your car get it to hot its done fans might be cheaper than a moter
Jul 29, 2012 | 2006 Chrysler 300
Hey, i added a trailer towbar and hitch ball to hyundai getz gvs 1.3 petrol model 2006, 82 ps hatchback. I believe ill need an extra cooling fan in front of the radiator.Plz help..
any 12 volt fan will work,the bigger the better co tack a close look at how much space you have to work with if any then look around in wrecking yards by seeing a few different fan assemblies you may get a better idea of what will fi and be the easiest to mountas for the wiringi woul try to run the wire to the fuse panel and tap into the fuse for the cigarette lighter and a toggle switch mounted on dash or a place you can reach whil driving. this way you have control of the fan, if the moter temp. begins to elivate flip the tiggje , changing the radiator cap may alow it to run at cooler temps or get a larger mor efficient radiator wich you can pick wil look nice.all this fuss for a 1.3 liter Hyundai to pull an extra 551 lbs. is a good thing you dont have a couple of fat mates
May 05, 2012 | Cars & Trucks
When i turn the A/C on, the temperature begins to rise and it begins to spill the antifrezze from the radiator reservoir. Dont know what the problem is.
You evidently have a problemwith your engine cooling system. Check to make sure that the cooling fins on your A/C Condensor and Radiator are not clogged up with dirt and debris. Check that your mechanical fan clutch has some resistance to pushing it by hand. If it spins too freely. the fan clutch could be worn out. Check to see how much air it is actually moving through the radiator. When the engine is at operating temperature and the A/C is on, This fan should be turning at a very high speed and blowing HOT wind in your engine compartment. I believe that your vehicle is also equipped with an electric cooling fan. The electric cooling fan should be running any time the A/C compressor is engaged. If not, then you must diagnose this failure.
Jan 23, 2011 | 2005 Nissan Frontier
Need instructions on how to replace the cooling
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Radiator upper crossmember
    • Fan motor electrical connector
  3. Drain cooling system below the level of the upper radiator hose.
  4. Remove or disconnect the following:
    • Upper radiator hose from radiator
    • Radiator fan fasteners and upper clip
    • Fan assembly by lifting upward to clear radiator
To Install:
  1. Install or connect the following:
    • Radiator fan assembly
    • Upper clip and fasteners
    • Upper radiator hose to radiator
  2. Fill cooling system.
Jul 17, 2010 | 2004 Dodge Intrepid
How do i change the radiator on a 2000 saturn SL2?
First drain the coolant, then move the intake out of the way , there are three screws hold it down.After that there is a hose that was kind of under the intake you need to remove that so you can get the cooling fan out once you have that done you have to remove the cooling fan there is a screw on the right side of it the rest of the cooling fan just pops out(DO NOT REMOVE
THE HOSES that may get in the way of removing the cooling fan those are to ur ac so un less u dont want that to work the dont do it). Then u need to get under and remove the plastic covers that protect the radiator there are some scerw behind the radiator u need to remove these cause they stupidly attached the ac cooler thing to the radiator .
After u remove thos u should be fine. there are also some screws and up at the top of the radator that keep it from move around after u remove those and the last hose thats connects to the radiator it should just pull out. after that u just put the new one in and put every thing back.
Oct 11, 2009 | Saturn SL2 Cars & Trucks
Whats the bottom moter with fan for
Refrigerators have a condensor fan so it can cool the compressor otherwise the compressor overheats and turns off.
May 11, 2009 | Refrigerators
Where does the radiator fan relay go
The Pulse Width Modulated (PWM) radiator cooling fan relay is located behind the front bumper fascia below the right headlamp a real pain to get at. supposed to take off bumper, grill, and r side headlamp assy. if youre crafty and have a mirror and you can locate this by eye. you can
"cheat" by using a hole saw to access relay and bolts. can be done without removing said items. be careful. and that will solve your cooling fan issues. common.
Nov 20, 2008 | 2002 Jeep Grand Cherokee
Change water pump
If you have any questions feel free to ask. Let me know if you dont get diagrams(happens sometimes)
0900c1528004319d.jpgReverse rotation water pump—2.5L and 4.0L engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this manual.
  2. Drain the cooling system.
  3. Remove or disconnect the following: NOTESome 4.0L engines are equipped with a fan clutch that threads Directly on to the water pump shaft. This fan clutch is equipped with right-hand threads. NOTEDo not store the fan clutch assembly horizontally, silicone may leak into the bearing grease and cause contamination. NOTEOne of the water pump bolts is longer than the others. Note the location for reassembly.
    • Negative battery cable
    • Electric cooling fan connector
    • Accessory drive belt
    • Engine cooling fan and pulley
    • Water pump pulley
    • Power steering pump
    • Lower radiator hose from the water pump
    • Heater hose
    • Water pump and discard the gasket
To install:
  1. Clean the mating surfaces of all gasket material.
  2. Install or connect the following:
    • Water pump using a new gasket. Torque the bolts to 17 ft. lbs. (23 Nm).
    • Heater hose
    • Water pump pulley. Torque the bolts to 20 ft. lbs. (27 Nm).
    • Engine cooling fan and shroud. Torque the bolts to 31 inch lbs. (3 Nm).
  3. Fill and bleed the cooling system.
  4. Start the engine, check for leaks and repair if necessary.
3.7L Engine
    • Fan and clutch assembly from the pump
    • Fan shroud and fan assembly. If you’re reusing the fan clutch, keep it upright to avoid silicone fluid loss!
    • Lower hose
    • Water pump (8 bolts)
  4. Installation is the reverse of removal. Tighten the bolts, in sequence, to 40 ft. lbs. (54 Nm). 0900c1528004319e.jpgWater pump tightening sequence—3.7L
Nov 15, 2008 | 2002 Jeep Grand Cherokee
Computers & Internet Logo
46 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
