Question about Garmin GPS
Acquiring satellites - Garmin GPS
  • 4 more comments
  • thehess75 Jul 02, 2008
    I have also had a problem acquiring satellites, I was driving when my GPS froze, it then read "having trouble acquiring satellites" Now every time I turn it on it says the same thing, and asks me if I am indoors. How can I reset the unit so that it is able to find the satellites?
  • nannerb27 Aug 18, 2008
    I have also had the same problem, my garmin won't recieve satellites, does anyone know the fix for this?
  • lalimeam Aug 31, 2008
    Whenever I turn my Garmin C330 on it cannot acquire satellites? I have used the reset feature but it hasn't helped. Not sure if there is a problem with a receiver in the unit?
  • mnrc31 Aug 31, 2008
    We have two Garmin GPS models.  We purchased the Nuvi 250W which has trouble, the unit is not acquiring satellites.  The other older model  60CSX we have will obtain them right away but the nuvi unit just says acquiring satellites but nothing happens.  I have owned the unit for 8 months now and this is not a start up issue the resolves it self.
    On occasion after starting up the unit, about 4 mins. later while searching for satellites  an error box will appear that states: Having trouble acquiring satellights, do you want continue?  Click yes and the unit will search to no avail.   I've have turn the unit off and have started over to have the same issue again.  With this many user issuers out there, I think Garmin needs to recall and correct this unit.
  • Anonymous Sep 15, 2008
    My 250W also has problems acquiring satellites. I've tried re-setting the unit, still problems. It's not totally consistant. Once in a while it acquires them quickly. Very FRUSTRATING! I just bought it two weeks ago and it hasn't worked on two TRIPS, which is why I bought it.
  • aspory501 Dec 29, 2008
    Keeps saying "Acquiring Satellite" but cannot find my locations. It thinks Im in Kansas!?
    New Friend:
  • 49 Answers
Garmin has a history of internal rechargeable battery problems that go back at least as far as the GPS III Plus. There is a button cell battery in the GPS III that is used to help it "remember" where to search for satellites (according to their tech department). It was supposed to have a 10 year life, but mine failed after 6 and they would not repair the unit. The unit would eventually operate, but as soon as power was turned off, it would lose all routes, waypoints, etc. That is not my idea of a good deal.
The 276C has a similar problem; if you leave it off of the charger for more than a day or so, the MAIN battery is fine, but the unit will not find satellites. There is a software fix for this if you have an older unit but it really doesnt fix it; the fix simply forces the unit into a mode that says "STORED WITHOUT BATTERIES" which is a misnomer; my batteries were in and charged, but I think what they meant is - the internal battery bit it.
If you reset the unit by holding the POWER button and the ZOOM OUT BUTTON at the same time, the entry screen will pop up. Accept the conditions and the unit will attempt to power up. I have had mixed success with this technique. The BEST technique is to LEAVE THE UNIT ON THE CHARGER at all times when it is not in use!!!!
Also go to their site and make sure that you have the latest software 5.4 and save your waypoints, tracks, etc., before you download the new software.
Mr. EE PE
Posted on Sep 24, 2009
The problem is normally caused by the rechargeable battery.
Open the case, disconnect the battery for 1 minute the put every thing back together. Should work!
Posted on Aug 28, 2008
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
Slow on picking up satelite on nuvi 260w
Good Luck. Did this help?
Dec 03, 2009 | Garmin nuvi 205W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
1,284 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
