Question about Clarity Hugo Lightweight Rolling Walker with Seat
Hugo walker wheel
My left front swivel wheel is hard to get it to turn the direction I want to go.
It want to go sideway or at an angle when I want to go straight.
  • Anonymous Nov 19, 2008
    The left front wheel on Mother's Hugo walker wobbles and it won't roll smoothly.
SOURCE: Interested in availability and price on Hugo walker w/seat
I bought one of these for my husband a couple of years ago and I bought it at Costco. Hope this helps.
Posted on Mar 21, 2009
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
Steering, The right front axle and tire lean in as if I were turning the steering wheel in the left direction but the left axle and tire remain straight. If I turn sharp to the left the right tire turns...
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
Aug 07, 2011 | John Deere Garden
Does the steering wheel control the wheels? Are the front wheels supposed swivel or stay in one direction?
theres no problem no the wheels arnt turned with steering wheel and the front wheels are supposed to swivel hope this helps if yes please giv thumbs up thanks
Mar 06, 2011 | Little Tikes Cozy Coupe
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Front swivel wheels fall off
I found your fee for 1 solution to be too high. I emailed the evenflo company and they helped me solve the problem.
Thanx for checking.
Aug 26, 2009 | Evenflo Baby Gear
Wheel broken for chicco DJ walker
I have the same problem and contacted Chicco UK directly. Provided that you live in the UK contact the company Storktalk on 01159306700 and the will send you a pair of replacement wheels for £5 including delivery.
Hope that helps
P
Mar 31, 2009 | Toys
Mar 02, 2009 | Clarity Hugo Lightweight Rolling Walker...
My quinny buzz front wheel keeps getting stuck half way and i end up trying to push the chair with the front wheel sideways which is impossible. i have been advised to clean the front wheel out as it gets...
First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
Now clean all the surfaces with a piece of strong cloth.
When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
Hope this helps! Dan.
Nov 11, 2008 | Quinny Buzz Jogger
Front wheels swivel and get stuck on each other
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
Sep 24, 2007 | Valco Twin Runabout ATS Jogger
Front wheel problem with Peg Perego Aria single stroller
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
Feb 12, 2007 | Peg Perego Aria MT Rubino Standard...
135 people viewed this question
Top Clarity Office Equipment & Supplies Experts
k24674
Are you a Clarity Office Equipment and Supply Expert? Answer questions, earn points and help others
