Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
WW30430 I have a Jenn-Air 30" Expressions Convection Wall Oven, Model #WW30430. When I turn the top oven on bake and press the temp. it just beeps. I can't see if a code is showing or not because the light is also out (Clock light)
Lower oven gives Fr code when turned on
Posted on Feb 02, 2010
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
My Jenn Air oven W27200B displays F2 error any solutions? Also one of the burners would hang- one worked and the other didnt.
HI. this is a failed oven temp sensor or relay board.
Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
Ohm test the oven temperature sensor, if OK, change power relay board.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
670 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
