Question about Carrier 38CKC036 Air Conditioner
Short circuit? the a/c won't go out. I changed the fuses. but the circuit breaker pops right away, suggesting there is a short. Thank you for your help, B. Dohmen
  • 828 Answers
Very possible your compressor is where the short is.
Posted on Jul 02, 2008
Do these ranges have a fuse? Kenmore range 91195291992
The first item to check is the circuit breaker or fuse box. It sounds like you shorted one of the hot wires to ground and that will trip a circuit breaker or blow a fuse. Next, with the range unplugged, remove the back panel and inspect wires going to bake element. You should see a black mark where it shorted. Repair connection if needed. Replace panel and plug back in. Reset circuit breaker or replace fuse and see if unit works. If not, the loud pop could be the control. Good luck!
Jan 29, 2016 | Kitchen Ranges
Hi, i herd a loud popping noise now my washing machine wont turn on at all there are no lights showing on the main board. please help thank you
check the house fuse board for a circuit breaker off
if that is the case get an electrician to check the machine as it has short circuited
Apr 25, 2015 | Washing Machines
Pops electric panal breaker
Hello friend, thank you for your post!
A dehumidifier is similar to having another refrigerator plugged in. It is recommended that it be plugged into a circuit of its own. If you are talking about the house fuse or circuit breaker it could be the circuit has to many products plug into the that house circuit. I would suggest moving it to another area of the house to see if it also blows that fuse. Hopefully this is helpful. -Matt
Sep 13, 2014 | Dehumidifiers
My washer keeps popping new circuit
You havent given details when the breaker pops. Is it right away, in wash cycle, spin cycle or drain? If it pops right away, there has to be a short circuit, but it fills water up then as soon as the motor starts n it pops, it could be motor. If blows during spin, definately motor drawing too much current. Then it could be the breaker that is weak/faulty. The breaker if not faulty it will pop if the current drawn by the motor exceeds it's rating or there is a short.
Aug 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
2006 street glide radio fuses keep popping
Hi Jamie, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 06, 2012 | 2006 Harley Davidson FLHX Street Glide
The circuit breaker on the unit pops almost every time I use the unit, what might be causing this?
Hi, when the breaker trips every time you turn it on, the unit has a dead short. It may have a frayed wire where it goes into the units motor, or the motor it self may be shorted out.A bare hot wire that touches metal will pop the breaker right away. I would look the cord over very well to see if anything may be bare. If not, the problem is further into the motor section of the unit, and more then likely the motor has failed. This is why the breaker is there for this reason. In case it overloads or you have a short, it trips to keep the unit from burning. Please keep me posted.
Sincerely,
Shastalaker7
Feb 05, 2010 | Vacuums
As i turn on microwave it blows the fuse. what could be the reason.
try using it at a different location in the house(different circuit) if it also blows that fuse, there must be a short in the unit. do not use. if it works means line in the kitchen is overload, and you need a higher fuse rating or breaker.
Sep 10, 2009 | Microwave Ovens
Electrical problem in motor home
id need to know what shorts to really tell you exactly want wire it is man but id really suggest grabbing a olm meter and testing every wire arround the short if thats what you think it is my friend
Nov 14, 2008 | Ford E-350 Cars & Trucks
Loud pop
You probably have a blown fuse (15A or 20A ceramic type) which may be caused by a blown part in the high voltage section. These are widely available at local stores. You can find exploded views and parts by entering your full model number here: http://www.geappliances.com/shop/prts/ If the new fuse blows immediately when you hit the START button, you also have a shorted high voltage capacitor. Need more help? http://www.fixya.com/ServiceRvw.aspx?advid=14&ctgid=153
Dec 15, 2006 | Kenmore 63652 Microwave Oven
Carrier 38CKC036 Air Conditioner Logo
51 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
