Computers & Internet Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brother tried to do a BIOS update. I dont know but something probably went wrong during the process and now, all my computer does is power on, no display, it wont even show the POST screen..
Anonymous
Level 3:
  • Master 707 Answers
  • Posted on Nov 26, 2010
Anonymous
Master
Level 3:
Answers
707
Questions
Helped
170325
Points
2245
Firstly, BIOS updates are precarious at best (especially for older computers and is not a decision to be taken lightly. They are rarely worth the risk.
Here is are some links that "MAY" help you recover from "failed BIOS updates or flashes".
WARNING!!!
Flashing or attempting to recover your BIOS should be done by a professional. I do not urge or endorse the use of these techniques, have no affiliation with the writer(s), and cannot be held accountable for failure. Again...this should be done professionally!!
That being said, I wish you success either way. You may have to copy and paste or type the first one.
http://www.associatedcontent.com/article/2026282/how_to_recover_from_a_failed_bios_update_pg2.html?cat=15
http://www.biosman.com/biosrecovery.html
http://www.informit.com/articles/article.aspx?p=27188&seqNum=7
http://superuser.com/questions/29221/how-to-recover-from-failed-bios-update
http://www.youtube.com/watch?v=_tEr_souZy0
Good luck. Hope this helps you.
1helpful
2answers
I was updating my dell latitude E6400 bios software but light went off during the process of updating and it's keeps showing invalid configuration
If the power went off during the process of updating the BIOS on your Dell Latitude E6400, it can cause the system to become unstable and display an "invalid configuration" error. Here are a few steps you can try to resolve the issue:
  1. Try to boot the computer: Turn on the computer and try to boot into the operating system. If it doesn't boot, try to boot into the BIOS by pressing the F2 key repeatedly when the Dell logo appears on the screen.
  2. Check the battery: Make sure that the battery is properly connected and has a charge. If the battery is low, it may cause the system to shut off during the BIOS update.
  3. Run BIOS recovery: Dell has a BIOS recovery feature that can be used to recover the BIOS in case of corruption. To run the recovery, you will need to create a BIOS recovery USB drive and boot the computer from it. Follow the instructions on the Dell website to create the recovery drive and run the recovery process.
  4. Try a different power source: If you were using a battery during the update, try using the AC adapter instead. If you were using the AC adapter, try using a different one, or a different outlet to make sure that the power supply is stable.
  5. Take to a repair shop: If the above steps do not work, it may be best to take the computer to a repair shop for further diagnosis.
It's important to note that running a BIOS recovery may cause you to lose all data on your computer, please make sure to backup your data before proceeding.
Ibm system x3500 BIOS update failure
Have you waited to see if anything shows for awhile (by awhile I mean 30mins to an hour.) Like you said it still could be updating.
My HP BIOS is not working the computer writes it new but during verification something goes wrong and then it flashes recovery fails. I am unable to use my laptop
That begs the question, Why did you flash the BIOS? Was the BIOS update on the HP website? Altering the BIOS and System Registry is like taking a stroll in a minefield, one wrong step and..............well you know. That said, you can try to remove the CMOS battery :http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
My acer laptop not responding my brother saying i have formated the bios setup by mistake now exactly dont know wether its bios or another problem really not getting any solution as i plug the charge in...
dude dont warry about it if u r brother were tried for updating bios then may be its the problm of bios program for that you need to go service center or ask to service engg to come u r place.
1helpful
How to update my asus p4sgl-mx motherboard bios
"BUPDATER BIOS Upgrade Procedure" read the Instructions/Procedure from ASUSTEK
Caution:
Updating your Mainboard BIOS is not for the novice, any errors ie.Wrong Bios versions or power failure occuring during your Bios process may render your mainboard useless!!! Do it at your own risks.
Hope it helps.
Hp pavillion dv4 1123 us will not power up after bios flash or update
Bios flash update is a very delicate process.
If something went wrong you lose your eeprom programmation. You can try loading it again but most of the times this is not successful so you should contact customer service and send your computer for repair process
Our computer is telling us we need to update the BIOS computer shuts itself off
All BIOS components are serviceable via a firmware upgrade that is known as "flashing" this process is called "updating the BIOS". The process itself is fragile since any power fluctuation during a flash may irrevocably corrupt a BIOS' firmware. Great care will need to be taken in order to safely accomplish this.
This guide will help you flash your BIOS by taking precautions and walking you through each step. Not all computers will have the same BIOS manufacturer, let alone the same process, but many have similar steps and precautions.
Guide: http://www.wikihow.com/Update-Your-Computer%27s-BIOS
Also check with your motherboard manufacturers website for specific BIOS updates and updating instructions. mpawlak908
2answers
Bios update failed *flash*
Did you make copy of your original bios before flashing...if yes then reflash with your original.
If No then trying reflashing again making sure no power cuts, dont touch computer until flashing is complete.
Are you using the correct bios for your MoBo?
2answers
No Power
This may be an unrecoverable issue. The bios are very touchy, it's the built in programming that allows the computer to work, never do a bios update directly from the internet, download, save, then run. If the loss of power corrupted the bios, in most cases they cannot be recovered, and since the bios is what tells the machine to power and run, cannot be reloaded. You will probably need to replace the motherboard. Take it to a tech (Bestbuy as a last resort), tell them what happened and see if he/she can recover it. Techs have diagnostic discs for this, however and again, if it won't power due to corrupt bios, the disc won't do any good and they'll probably tell you the same, motherboard replacement. I hope I'm wrong on this and it's just something simple.
Will not boot into Bios
hmmm... why dont you try to reinstall your OS...maybe there's something wrong with that..^ ^
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
