Question about E-Machines eMachines Desktop PC
Modem After needing to run my restore disk on my three week old P C my modem no longer works.I have emailed tech suport at gateway their solution does not work I need to see fix computer at the begining and it shows safe mode instead mod#T3646.
    Sergeant:
  • 329 Answers
Unistall modem, remove turn on , then turn off and install modem and see if e machine will find drivers. What kind of modem, down load drivers from site.
Posted on Jun 23, 2008
How to acess modem
To access a modem, you need to connect your modem directly with your computer using ethernet cable.
Then you need to click on start and click on RUN. Type in there CMD and press enter.
In case of Vista, type in CMD in Start Search then right click on CMD which you got asd result and select "Run as administrator".
It will open up a black screen. You will get a blinking cursor. Type in there ipconfig and press enter.
It will show you three details which will be
IP address
Subnest mast and
Default Gateway
You need to note down the number written in default gateway.
Now open up Internet Explorer or Firexfox.
Clear the address bar and type in number which had noted in above step and press Enter.
As per you modem setting it might ask you your modem username and password else if it doesn't happen then you will be able to get your modem firware page.
You can yry following username and passwords:
Username: admin
password: Blank (I mean simply press enter)
Username: admin
Password: Password
username: admin
Password: admin
Take Care
Enjoy :-)
Jun 30, 2010 | Arris SURFboard Cable Modem
Belkin F5D8236-4 Wireless Router will not connect to pannaway dsl modem with same settings as router I am replacing. Dynamic IP address setup. Modem light continously blinks orange. No internet light.
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Oct 03, 2009 | Belkin F5D8236-4 Router
Qwest DSL / Issues with Motorola 3347
The modem overheats due to lack of ventilation. I fixed mine first with Ice packs then a small twelve volt fan and some inexpensive heat sinks glued to the top of the two processor chips.
You need to cool the modem down!
Jul 24, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Restore a gateway 505gr
I got a gateway 505gr that I had to restore , but I lost the disc . So I used another disc. from my newer gateway and it worked . I cant promise you anything but I will see if I can burn you a copy to try if interested . if not I got a copy of window xp pro that I can send you that will work. you can email me at rbright13@hotmail.com .
Nov 10, 2008 | Gateway 505GR PC Desktop
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Slow WEB with Netopia 3347W
don't worry, there is a major fault in the cable , cable in the mediterranean is damaged and the international gateway is not opening, it will take few more days to set it right, then speed will be fine
Feb 04, 2008 | Computers & Internet
MODEM FRIED, NOW I GET COM1 ERROR WHEN REINSTALLING VIA CD(S)
If it's a separate modem card, replace it.
If it's the built in modem, you'll need replace the mother board.
If you have an extra slot, you might be able to install a cheap add-on modem card which should override the built in. But that's a long shot may not work but worth a try.
Nov 05, 2007 | Gateway 507GR PC Desktop
RCA DCW615R WIRELESS Cable Gateway , Factroy Installed Firmware needed.
I had the same issue with my RCA DCW615R. First time my ISP Comcast flashed it back to the old version. This time I could not find anyone who new how to do that. I used to have the software and I have searched the net. Seems they provider RCA does not have it.
This time I called Comcast because I noticed that the 192.168.0.1 brought me to their software update. They supplied me with the user name and password. I was able to get into the firmware and change all the settings using the new firmware. I think the only reason they gave it to me is because my printer is a network printer and it would not work unless I could access the firmware.
The old 192.168.100.1 does not work anymore because that was Cable Modem mode or CM mode. The new address 192.168.0.1 does work but you will need the user name and password from your ISP, this is RG mode or residential gateway mode.
Liked the old firmware better but they both do the same thing. Seems the Gateway works better with the new update. Still I would like to find the old firmware not sure why RCA doesn’t have it.
Feb 11, 2007 | RCA DCW615R Wireless/Cable Modem
E-Machines eMachines Desktop PC Logo
77 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
