Question about Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200gtl High Power Transmit problem??
This radio connected to a 25 amp power supply and running high power on Cobra 200gtl.. When transmitting,on high power, the needle moves properly and output power is good for a few seconds then within 2 seconds the power drops off rapidly , needle in meter then does slowly drop away under ssb modulation till it does not react at all. On low power the transmitter is ok ....Any solutions??
  • ozradio123 Sep 26, 2008
    thanks for the advice
    the problem was the RF Transistor (RF16FF1) was loose and overheating . now fixed thanks
  • 90 Answers
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
Posted on Sep 26, 2008
  • 1 more comment
  • stratomas59
    stratomas59 Feb 18, 2014
    There were severalhundred radios maybe a couple of years worth and I don't know what years they were but that is a very well known problem with some of the Cobra 200 DX gtl's that had this problem along with a few more. Later rewvisions were fixed for that problem as well as some other problems. I think that most of the later model revisions had most problems fixed. I habve been tol;d by radio techs that 2007 was the last year that Cobra made them and supposedly by then most all if not all of them were working good. Unless you are a compentent radio tech my suggestion would be for you to take the 200 to a tech and explain your problem. I know it can be fixed. Bob
  • Kelvin bell
    Kelvin bell Mar 23, 2014
    Could it be the power output is to high at 120watts ssb?
  • Kelvin bell
    Ok thanks bob,it sure is a pain.
My cobra 200gtl rev 2 cuts out on ssb after a few minutes
It sounds like the final transistor may be shorted/burned out. If you don't know how to locate or test the transistor you'll have to take it in to a tech. These transistors are usually quite cheap but as to the labour cost it depends on your tech. Usually what causes this damage is a bad antennae match or a bad antennae itself, even a shorted antennae cable. After you've repaired the radio check the antennae and cable first before connecting it up again, then check your match with an SWR meter. Good luck
Mar 23, 2014 | Cobra 200 GTL DX 4-Channels Base CB Radio
Swr on channel 1 and 40 are over 3, what can I do?
Check your antenna. Make sure it is getting a proper ground. If mag mount; make sure base of antenna and where you put it are both super clean. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Tom
Jul 15, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
I have a cobra 25 ltd classic change final to 1969 now I can hear but no transmit. Final is new ......where should I look next?
Was the radio working before the high power transitor mod?
If so, it appears there is more to do than just replacing the transistor.
Check www.worldwidedx.com under" cobra 29 high power mod with 2sc1969 transitor." There are instructions for the complete mod.
Hope this helps
Radioman
Jun 18, 2012 | Radio Communications
I have a cobra ltd29 and I seem to be able to send very clearly but I am not able to receive unless I am right next to the other radio.
Without more in depth detail you have had your receive damaged by a high power radio transmitting near you. I suspect a blown diode or tr7 the first RF amp transistor has failed.
Now it you are describing a low volume problem. Like the volume of your radio not increasing when you plug it in that can be a broken with in mic cord, bad switch in handset or solder connection at mic plug. It will still transmit.
Jun 27, 2011 | Cobra Radio Communications
My cobra 200gtl has no transmit
hi More than likely your pa transistor has blown have you checked it with a power meter if so r you getting the red tx led when the ptt is pressed if so then your problem lies with the rf transistor
replacing rf transistor
Jan 18, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
I have a cobra 25 ltd and when i key the mic the gauge of the db barley goes up. is something wrong ? also the gauge says its measuring tx power what does that actually mean/ do
TX means transmit. There are 3 settings for the meter. The top one is to measure your TX/RX that's transmit and receive. CAL is to calibrate the meter to check your SWR.
Reasons your needle may not be moving much when you key while on TX/RX. The dynamic is probably all the way down. That is your mic gain. If you turn that up when you talk the needle will swing more. If the radio is stock and not modded, you can turn this all the way up and leave it.
Also there could be something wrong with the mic. If people can hear you then its not the mic.
If people can hear you fine when you transmit, it may just be a bad meter. Not a big problem, you will just need an external meter to make sure you swr is not high.this is important because if it is over 1.5 you run the risk of blowing the final transistor.
Oct 11, 2009 | Cobra 29 LTD CB Radio
Swr too high
Check your antenna. Make sure it is getting a proper ground. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Tom
May 26, 2009 | Cobra 29 LTD CB Radio
My icom 706 mk2g powers up, receives, but when i push the mike ,the radio turns off, help
Hi
I had a similar problem on my 706 MK1. The problem was corroded connections on the white power connector at the rear, When on tx the voltage drop across this connector was great enough to switch the radio off. try cleaning/re-seating this connector
EI4HO
Dec 10, 2008 | Audio Players & Recorders
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
512 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
