Question about Brother IntelliFAX 2800 Laser Fax
Brother lntellifax 2800
I have a brother lntellifax 2800 i dont know what happened to it but from one day to another it stop reciveing or sending faxes it still makes copies just no faxes help i work from home thank you
  • Anonymous Jun 27, 2008
    The machine has problems faxing out. Frequently it says 'poor line condition'- I have had the line checked- no problem. Ocassionally, if I unplug the fax it works.....ANy suggestions?
    Thanks
  • Anonymous Jul 08, 2008
    I can send faxes but I cannot receive faxes. There is a dial tone. I unplugged the machine but it did not fix the problem. The rest mode shows the date, the time and "TAD". Does that mean anything. When a fax was trying to come through, I even hit the fax start button but it did not work.
    Sniper:
  • 57 Answers
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
Posted on Jun 24, 2008
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
Intellifax 2800 fax machine
my suggestion would be to down the manual from brother.com
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Can receive, can't send
I spoke to someone at Brother. She told me to "massage the keys in a circular motion". Feeling very foolish I did this. Sure enough when I got to the number "7" it was stuck. The massaging released the key and my fax was working again.
Mar 31, 2008 | Brother IntelliFAX 2800 Laser Fax
How to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Feb 27, 2008 | Brother IntelliFAX 885MC Plain Paper...
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
