Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Load
We recently purchased this washer and no suds are visible during the wash cycle. Is this normal? I know it uses less water, but I should be able to see SOME suds, shouldn't I?
  • 413 Answers
If you are using the recommended HE (High Efficiency) soap, you will not see alot of sudsing, this is normal. The washing action is very different than the top load machines. Excessive sudsing will cause issues with this machines operation.
Regards;
reg501
The FixYa Team
Posted on Jun 24, 2008
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SUD in display
The SUD message relates to overdose of detergent detected during the Wash Cycle.This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked.
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do you get the 'suds' to stop appearing on the screen. have tried rinsing but it wont let me.
SUDS = suds detected during wash cycle.
Do you see suds visible in the drum?
Do you have any other failure codes appearing?
Unplug unit and plug it back in attempt to run the rinse cycle. If it does not work it could be a clogged filter.
Remove lower front panel place a pan under the white filter. located near the pump. Remove the unit and clear any debris.
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load and suds
if you use washer without cloth you will some water and it is normal..use different detergent and use less you will be ok..hope that help you.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
noisy may be the tub is hiting some thing. you can open the top of the washer and ck. it is very simple. sud are you using the he soap.
Feb 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Low water level
It depends on how old the machine is, the newer machines by law,take in way less water but still wash ok. TIP.try it with out load and check water level Ire bye
Nov 04, 2007 | Whirlpool GHW9200L Front Load Washer
Display panel reads SUDS
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Oct 28, 2006 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal De
